need model number for intergrale injectors used for zt?
im looking at buying some injectors from a intergrale but need more info, is it a 16v one or 8v one?
Cant help you with that, but if its for a zetec turbo (i assume thats what you mean by ZT) then what management are you using?
If its capable of living with high impedence resistors (like most management is as far as im aware) then calibra turbo ones are good for 300bhp and a decent idle on a 2.0 engine are available very cheap secondhand.
ZXR injectors are available for under 70 quid delivered brand new, and are good for 400bhp and still idling perfectly on a 2.0 engine.
Apologies if thats no use to you cause it MUST be grale ones but thought it was worth mentioning just in case.
