STAGE 3 BIG STAINLESS VALVE CYLINDER HEAD!! EFI
Old Nov 1, 2007 | 04:10 PM
davsmith64's Avatar
davsmith64
Default STAGE 3 BIG STAINLESS VALVE CYLINDER HEAD!! EFI
you are looking at a stage 3 big / stainless valve cylinder head from a ERST EFI TURBO!!!
got larger stainless inlet valves, and larger ex valves, all valve are multiangled too, comes with lifters androckers, also will throw in a KENT CVH37 cam with it..
been fully gasflowed and ported,,
little det marks but nothing major at all
the head was at area six (ian howell) for 3 months while he inspected it ect then i got it back.. he says that the work is top qualiy work done to this cylinder head!
i need a fast sale!!
£300 ( cost me £600 with the lifters & cam )
can travel to meet at cost of fuel (gas)
Old Nov 1, 2007 | 06:07 PM
V8ian's Avatar
V8ian
Default head
have u got any pics m8
Old Nov 1, 2007 | 07:39 PM
davsmith64's Avatar
davsmith64
Old Nov 2, 2007 | 03:30 PM
ladsarmy's Avatar
ladsarmy
Default head
could i put this on my s2 escort rs standard would i make a difference i have a stage 3 turbo stainless usual standard bottom end let me know cheers
Old Nov 2, 2007 | 06:33 PM
davsmith64's Avatar
davsmith64
you will need a conversion plate that goes between the injector rail.. as it has slots in the ports for efi injectors,, it would be a good result with your stage 3 turbo also..
Old Nov 2, 2007 | 08:02 PM
V8ian's Avatar
V8ian
Default head
is there any way u could send the head m8
Old Nov 2, 2007 | 08:18 PM
ladsarmy's Avatar
ladsarmy
Default head
what do you mean by conversion plate is it easy to fit
Old Nov 2, 2007 | 09:13 PM
davsmith64's Avatar
davsmith64
i prolly could send it to you but the postage may be high..
yeah the conversion plate is piss easy to do.. spacer between inlet manifold and head..
Old Nov 3, 2007 | 11:57 AM
ladsarmy's Avatar
ladsarmy
Default hi
so just a case of slotting it between then and the gasket cheers
Old Nov 3, 2007 | 12:25 PM
davsmith64's Avatar
davsmith64
yep u got it mate
Old Nov 3, 2007 | 01:25 PM
ladsarmy's Avatar
ladsarmy
Default hi
where would a get one can you post to GLASGOW could you get me one included in the price are they expensive
Old Nov 3, 2007 | 01:41 PM
davsmith64's Avatar
davsmith64
ferriday do em but they £93 but try jano @ oddkidd creations,, sorry mate cant add one in with the price, regards dave
Old Nov 3, 2007 | 08:16 PM
ladsarmy's Avatar
ladsarmy
Default hi
ok if you still got it on monday a will av it just need to find a conversion plate now mmmmmmm
Old Nov 4, 2007 | 01:52 AM
davsmith64's Avatar
davsmith64
ok mate no worries..
Old Nov 5, 2007 | 10:31 AM
James Raby's Avatar
James Raby
He's told you where to get on from, it ain't hard
Old Nov 6, 2007 | 10:00 PM
V8ian's Avatar
V8ian
Default head
hi m8 have u still got the head. if so when is the best time 2 come down and buy it
Old Nov 7, 2007 | 07:00 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Thats expensive
Try the second choice first.
Marcus L
Aug 29, 2015 02:18 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
turbotrev
Aug 22, 2015 11:41 AM
Bobby9779
Aug 11, 2015 06:47 PM
Blown Hell
Aug 5, 2015 07:22 AM
