engine rebuild
Old Oct 31, 2007 | 06:27 PM
lukeyboy's Avatar
lukeyboy
Default engine rebuild
hi ppl
can anyone tell me what an engine rebuild consists of.
cheers
lukeyboy
Old Oct 31, 2007 | 07:09 PM
base190380's Avatar
base190380
block rebore, cleaning oil galleries, new pistons, rings, main bearings, big end bearings, and crank grind if needed. new oil pump seals gaskets, new sump, oil pump, new core plugs, cylinder head work done, etc and i could go on. why?
Old Oct 31, 2007 | 07:35 PM
lukeyboy's Avatar
lukeyboy
i think iv got low oil pressure on my s2
Old Nov 1, 2007 | 07:53 PM
Aaroncast's Avatar
Aaroncast
YOU EITHER HAVE OR YOU HAVNT?????????????????
WHICH ONE IS IT
IT COULD/AND WILL MAKE A DIFFERENCE!!LOL
Old Nov 2, 2007 | 03:55 PM
lukeyboy's Avatar
lukeyboy
well i had new cams put in and after 3 days the follwers needed changing again the old cam kit was in the car 6 years, i took the new cam kit out and sent them back to the manufacturer to see if they were faulty or it was my engine
ppl were saying the reason for the for the new follwers gong so quick might be because of low oil pressure or oil starvation, but the manufacturer have sent me a new cam kit.
im now having a oil pressure gauge fitted.
Old Nov 2, 2007 | 04:15 PM
SafeChav's Avatar
SafeChav
What cam did you have fitted and did you allow it to bed in before thrashing the bollucks off it
Old Nov 2, 2007 | 05:30 PM
lukeyboy's Avatar
lukeyboy
piper 285t2 and i couldnt thrash the bollocks out of it because it was running to much boost
Old Nov 3, 2007 | 11:03 AM
SafeChav's Avatar
SafeChav
Piper cams are renowned for being shit, in terms of durability and performance.
Get yourself a standard cam
Rstar_man
143
Jul 20, 2020 11:16 PM
Wilsfoci
15
Mar 30, 2016 10:26 PM
cossiedean84
37
Sep 2, 2015 10:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
