cranke case presuer or smoke
i have fitted new rings big ends and head gasket and bolts and steam seals and turbo in a m8s car and out off the breather ther smoke its like exshust gases or crankcase pressuer but i have changed every thing related any help would be gratefull
I may be able to help a little bit as karl [NMS] diagnosed the same problem on mine.....
It's a result of possible bore glazing, but new rings and head gasket sorted mine. He did tell me worst case though that the criss crossy bits on the pistons could have worn away/off [how technical am I????
]which causes oil to get into the fuel or the other way round, christ I'm useless, ask Karl he's a top bloke and will help you out
Steve Escos
Oct 1, 2015 06:57 AM
muz
Sep 30, 2015 08:29 AM
