rear diff oil seal
Old Oct 27, 2007 | 04:22 PM
D-Sport's Avatar
D-Sport
Default rear diff oil seal
as above guys, can it be done in situ or does the diff need to come out, also is it easy to replace or do i need some special tools
its an escort coz 4x4
dave
Old Oct 27, 2007 | 06:08 PM
D-Sport's Avatar
D-Sport
lookslike all the mechanics are off tonight
Old Oct 28, 2007 | 02:50 PM
D-Sport's Avatar
D-Sport
anyone at all
Old Oct 28, 2007 | 03:17 PM
Moonstone Mart's Avatar
Moonstone Mart
Can be done in situ.
Pics from a 2wd saph but still the same.
Unbolt the drive shaft on the side you want to change.
Remove the rear diff cover (get something to catch the oil in when you take it off)
The stub axle has a circlip holding it in the diff. You can just make it out in this pic.
Pull that off and you should be able to pull the stub axle out of the diff.
Seal pic.
Remove old seal
Fit new seal.
Fit everything back together (use some sealant when refitting the diff cover)
These pics are from when i stripped/rebuilt my diff. When you get the rear cover out take a look at the gears inside. Mine didnt whine or anything but the teeth on the gears were chipped and very worn!
Mart
Old Oct 28, 2007 | 03:25 PM
dojj's Avatar
dojj
Resident Wrestling Legend
which seal?
the output or the pinion?
easier to teak the diff out but can be done in situ
Old Oct 28, 2007 | 03:29 PM
Moonstone Mart
oh yeah good point doji. I assumed it would be output.
Mart
Danielbetty
Aug 28, 2015 08:01 PM
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
st220kyle
16
Aug 14, 2015 06:13 AM
Gadget
Aug 13, 2015 08:19 PM
xr4x4rs
Aug 6, 2015 09:03 PM
