HELP
Old Oct 27, 2007 | 04:17 PM
madrs247's Avatar
madrs247
Default HELP
right,a lot of u have said to fit the s2 rad due to being unable to by a new fezzer rad
ive bought one,and the double core cooler,but what a twat to fit
have any of u lot got any pics with the s2 rads fitted with cooler,and what did u have to do to get it sorted
cheers
stu
Old Oct 28, 2007 | 12:43 AM
jacko's Avatar
jacko
iv cut the back out of the bumper and put a long universal one in behind it with pipe work going to where i need it the reason your having trouble is that the cooler now fits too far forword because the rad is in the way your other choice is to put a standard cooler back in mate so its thiner
Old Oct 29, 2007 | 03:43 PM
frsjon's Avatar
frsjon
hello mate any luck with the fitting??? there is a bit of work to fit them but it will be worth it once in.....i have no pics at mo or camera ....ill see what i can do...
Old Oct 29, 2007 | 07:17 PM
madrs247's Avatar
madrs247
well,ive got the cooooonts in now,it dont look TOO bad,but a need to get the welder out of the garage and fit some brackets to keep the rad sitting forward as to miss the actuator and tubby
ended up cutting the front panel down about 15mm and had to cut a gap in the lower slam panel(x mamber) to allow fitment of the bracket on the rad
ill get pics 2morro,but even though its all fitted the fooker overheasts like fook
i HAVE change the thermostat and fanswitch,but fan dont come on-yes it does work)
dont seem 2 be pressure in the top rad pipe
cars off the road AGAIN
Old Oct 29, 2007 | 08:49 PM
frsjon's Avatar
frsjon
sorry mate ,feel guilty mentioning the s2 rad....maybe holding out longer for a fiesta one would of been better....would there be any chance of air being trapped in the rad?? there a bit off a bitch to bleed as there nothing to bleed from... ..
Old Oct 29, 2007 | 11:07 PM
madrs247's Avatar
madrs247
i have no fookin idea mate
its overheating like a biatch,i have no heaters inside,found more rot in the floor pans and im getting peeved off now
i wanted to be able to drive the ar BEFORE stripping the fooker
