sierra repair - speed / ease ??
Old Oct 6, 2004 | 04:11 PM
elador's Avatar
elador
Default sierra repair - speed / ease ??
i've got a 2.8 sierra 4x4, which needs the following done (most of the bits i have) :-
renew both rear axle main carrier bushes
renew n/s rear coil spring
power steering (power loss): suspect power steering rack - replace & retrack
renew/ weld rear section exhaust
emissions problem (high Co2) - suspect misfire - plugs, leads, sticking valve ?
ABS lite fault ??
welding req'd :
both front footwells
o/s outter sill under door
both sills at rear backing areas
rear o/s outer drive shaft cv boot
" " front wheel bearing
how easy / quick do u think i could have it done bearing in mind a few things
1. female
2. skint
& 3. practical knowledge limited altho' improving
Old Oct 6, 2004 | 06:08 PM
Moose 130's Avatar
Moose 130
renew both rear axle main carrier bushes - Ł60 + bushes (polys Ł20)
renew n/s rear coil spring aprox Ł45 for spring
power steering (power loss): suspect power steering rack - replace & retrack Exchange rack IIRC Ł160 Ł70 fitting track Ł25
renew/ weld rear section exhaust Ł20 +parts
emissions problem (high Co2) - suspect misfire - plugs, leads, sticking valve ? HC's would be high with those probably simple adjustment
ABS lite fault ?? sensor? expensive new Ł90ish?
welding req'd :
both sills at rear backing areas Ł160ish for the lot
rear o/s outer drive shaft cv boot Ł75
" " front wheel bearing Ł60 +parts
all prices are guesstimates and should not be relied on.
not wanting to sound like a wanker, but is it worth it? even if you are DIYing it there is a fair bit of ŁŁŁ that need to be spent.
Good luck if you decide to go for it though.
Old Oct 7, 2004 | 10:18 AM
elador's Avatar
elador
renew both rear axle main carrier bushes - GOT
renew n/s rear coil spring - GOT x 2
power steering (power loss): suspect power steering rack - replace & retrack - GOT
renew/ weld rear section exhaust - CAN GET & CHEAP
emissions problem (high Co2) - suspect misfire - plugs, leads (CHANGED & ROTA-ARM), sticking valve ?
rear o/s outer drive shaft cv boot - GOT (I THINK)
JUST THE WELDING THAT WOOD STING ME xx
Old Oct 7, 2004 | 10:25 AM
mark's Avatar
mark
for the price of one with an mot i dont think its worth doing to be honist
you can find good 4x4's cheep
got my one fr Ł50 had to get calipers for it to pass an mot tho but its solid
Old Oct 12, 2004 | 11:37 AM
elador's Avatar
elador
Thanks 4 ur support guys - Christine's my baby, can't be getting rid of her . . .
will keep u updated tho
155lee
Sep 6, 2016 11:10 AM
nico12
Dec 31, 2015 04:42 PM
routemaster
Sep 7, 2015 05:27 PM
yorkie92
Sep 6, 2015 05:34 PM
Adam Graham
Sep 6, 2015 06:04 AM
