cosworth non starter
Old Oct 25, 2007 | 05:50 PM
cosmatt's Avatar
cosmatt
Default cosworth non starter
Please help me guys,i got a 2wd saph that just refuses to start. The plugs are not getting the fuel for some reason. I took injectors out and replaced them but before puttin them back in,i cranked the engine to see if they are spraying and they arent. They all pulse when you turn the ignition onbut when cranking over its all over the show with usually just one pulsing. ive changed the crank and phase sensor and tried a different ecu. Any ideas??? Many thanks...
Old Oct 25, 2007 | 06:54 PM
155lee's Avatar
155lee
Default fuel pump
hi,go into your boot,take out the spare wheel,underneath it fixed to the boot floor is a black box,on top it has a grey button,push it in and this should fix it,its a fuel knock switch,if it isnt that then i dont know.also,how does your car drive with the escos wheels?does it tramline,rub the arches etc,how far do they stick out at the front?good luck,lee
Old Oct 25, 2007 | 09:10 PM
cosmatt's Avatar
cosmatt
Got a direct feed to pump at moment. My car drove fine but had wings pulled out to not catch. Its the injectors that arent pulsing..
Old Oct 25, 2007 | 09:53 PM
155lee's Avatar
155lee
not a clue then pal,just speaking from experience,seen the new sets of 18 inch escos rims?really nice,think you would have clearance issues on a sapph though!good luck with the car.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
