dual mass flywheel
Old Oct 25, 2007 | 04:54 PM
freakyford's Avatar
freakyford
Default dual mass flywheel
is there a way to test if dual mass is causing my vehicle not to start its a 53 tdci 130 psi
there are no codes stored and the fuel system has all been checked
Old Oct 25, 2007 | 06:12 PM
Dave McB's Avatar
Dave McB
a dmf fault aint gonna cause that.
here goes: (im a parts salesman and got the tech bulletin from ford)
The dual mass flywheel (DMF) as it wears causes dust to build up on the starter motor. This in time causes your starter motor to fail.
If u change the starter motor u must clean the area with hi pressure air hose before fitting new starter or it will invalidate warranty.
Failure of DMF usually consists of excessive clutch slip and/or 'clunking' from the gearbox area (main sign of wear of the DMF)
Old Oct 25, 2007 | 07:35 PM
mechanic28's Avatar
mechanic28
DMF r shit nothing but trouble it is poss for it to stop it starting if your crankshaft sensor is situated in the gearbox behind the flywheel like vauxhall Z18xer engines dust stops sensor from reading
Old Oct 25, 2007 | 08:06 PM
dave green's Avatar
dave green
Dual mass flywheels tend to shag starter motors, as said above dust.
if the centre of the flywheel moves more than 1.5cm from side to side then its fooked
Dave
Old Dec 8, 2009 | 01:47 PM
mondeoman_11's Avatar
mondeoman_11
Post Mk3 Mondeo TDCi dual mass flywheel fualt
Found this post interesting as it contains the tech bulletin from Ford. I have just had my Mk 3 Mondeo's failure to start diagnosed as "starter failure due to debris from dmf". Ford suggested that both flywheel and starter need to be replaced at a cost of over £1500! The car is an o5 reg with 54k so I argued that ptting a new flywheel on mightn't last - to which the response was 'it will do another 50k'.
Im going to have the starter replaced with the logic being the dmf will do another 10-12k by which time I'd have sold it. the tech bulletin above give some support to this theory as there appears to be no other syntoms beside the failure to start...yet. watch this space...
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mark_
14
Jan 16, 2016 05:27 PM
Jman-pat
Ford Focus Diesel
Nov 8, 2015 01:29 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
