my new 2.8 capri special
Originally Posted by escort_cosworth_monte_163
cheers guys ive also got a cosworth but ide sooner drive the capri anyday
simple answer, cosworth engine....
into the capri
just get some lazer/2.0S engine mounts and your 99% of the way there
nice car there
into the capri
nice car there
Cossie Capri is what i'm building at the mo
into the capri
nice car there
just know cossie engines dont come cheap
Well it's taken me a few years to get my bits together, but i'm builidng virtually from scratch,here's a link to the project i'm doing ....
https://passionford.com/forum/viewto...897&highlight=
Sadly though, I think I gotta strip the engine down before I get it running,as I think the head has been skimmed below 136.7 mm and seeing as i'm running BD 10's I could end up with pistons kissing valves
LOL i'd hate to add up how much it's cost me over the years lol
lolol!
niiice project, any tips for what brake conversions can be done on the capri???
on a short run (30-40minutes) ive been having problems with the std brakes gettin so hot they glow bright red for about 5minutes until they cool down naturally....
looks cool, generally not too good!
also can you take the brake shroud off the inside of the front brake disks, or is this to protect stuff behind the caliper itsself and deffo needed??
lolol!
The setup i'm going to be using,uses his modified hubs,so the disc sits at the front of the hub,not the back,using I think either a Sierra or Escort Disc. RS Turbo S2 calipers,2.0L capri servo and Land Rover master cylinder. And rear disc conversion also using Sierra Bias valve,so I don't lock the rear end up.
lolol!
well thats coming off asap lol!
well keep me updated on how the conversion goes and how much+how well it works, these brakes are shoddy at the best of times
STAFFY OWNER
Sep 13, 2015 08:59 PM
heres a few pics of my new 2.8
yes it is indeed only done 46k with all history ,its the best 2.8 ive had its my 5th capri
so if anyones selling one preff a magnex please pm me
