speedo cable
Old Oct 23, 2007 | 03:46 PM
muffster's Avatar
muffster
Default speedo cable
Hi fellas.
Can anyone tell me how to disconnect the speedo cable from the back of the clocks. ive got it all in bits but cant seperate the cable connection from the back of the clocks.
The needle on the speedo is bouncing around all over the place and the mileage isnt changing!!!!!
Cheers.
Muffster.
Old Oct 23, 2007 | 03:48 PM
lukemakepeace's Avatar
lukemakepeace
what car?
Old Oct 23, 2007 | 03:53 PM
lukemakepeace
if its a non electrical one it should just pull straight out.
Old Oct 23, 2007 | 05:50 PM
muffster's Avatar
muffster
"what car"
Yep, fair point mate, that would help!!!
Its a sapphire cos. There is a metal connection on the end of the cable and some sort of plastic holder which all fits onto the the back of the speedo. It looks like a push fit or a bayonet connection but i cant seperate them and dont want to f**k the clocks up.
Thanks.
Muffster.
Old Oct 23, 2007 | 06:46 PM
antony215's Avatar
antony215
Escort Rs Turbo
you need to pinch the plastic part so it unlocks then it should just pull out
Old Oct 23, 2007 | 07:26 PM
Mr C's Avatar
Mr C
as above mate, squeeze the wide bits together and pull out
Old Oct 23, 2007 | 07:49 PM
dkmk4's Avatar
dkmk4
same as the mk4 escort squeese the plug and it sould pop off
Old Oct 24, 2007 | 02:43 PM
lukemakepeace
yep nice old manual ones. just squeese and pull, you wont do any damage to the closck guarranteed.
muz
Sep 30, 2015 08:29 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
sto6enc
Ford Mondeo Including ST
Sep 21, 2015 11:31 AM
Bransby
Sep 14, 2015 08:54 PM
