escort rs turbo firing order
Old Oct 23, 2007 | 08:53 AM
FEZZYXR2IT's Avatar
FEZZYXR2IT
Default escort rs turbo firing order
as above i know it is 1 3 4 2 but has any1 got a pic of the dizzy and which 1 is number 1 and if its clockwise or anti clockwise
thanks steve
Old Oct 24, 2007 | 05:28 PM
andyuk's Avatar
andyuk
Default hi
if your timimng is correct then remove the dizzy and crank the engine to see the rotation, then as you look at the engine the left first piston is number 1 when this is at tdc your rota will be pointin at number one, then go from ther 1342, pretty sure its clocwise
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
Vincereese
Aug 18, 2015 03:57 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
