Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Wierd knocking (Escort Si 1996)
Old Oct 22, 2007 | 12:04 PM
carla5's Avatar
carla5
Default Wierd knocking (Escort Si 1996)
Hiya
Just notcied over weekend if I pull away or reverse slowely, when I stop I'm getting a strange knocking noice coming from the front of my car, sounded like a caliper sticking a little but I had them replaced along with hoses last year, just recently bought 2 new bottom arms for MOT which are ye to be fitted so hope that cures it.
Could it posibly be an engine mount??? only does it when am going real slow forward or in reverse
Also is it easy enough to replace a hand brake cable on Escort Si mines vertical at minute and MOT's next week
Any help would be much appriciated
Old Oct 22, 2007 | 12:41 PM
djmillsy's Avatar
djmillsy
Fife Radge
handbrake is a doddle to change mate unless you have siezed bolts.
to check the enigne mount get a mate to sit in the car and rev it while you watch the engine if its moving all over the place its fooked............it will move a little
on the knocking could be ball joints or wishbones to check jack it up and rock the whell side to side if it knocks its the cv joint and rock it up and down if it knocks its the ball joints good luck mate
Old Dec 12, 2007 | 05:24 PM
phill295's Avatar
phill295
alos check drop links common fault you will feel a knocking from the 2 ball joints when you try to move the drop link up and down
hope it helps
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
BRAM
Sep 8, 2015 07:11 AM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
