RST S1 vs S2 ECU compatibility?
Old Oct 21, 2007 | 11:29 PM
Ade's Avatar
Ade
Fast Ford snapper
Default RST S1 vs S2 ECU compatibility?
I've got an unused Turbosystems chipped S1 ECU, just wondering if it could be used in an S2?
I know the ECU has no S2 knock sensing function, but would it work just the same apart from this?
Old Oct 22, 2007 | 12:27 AM
rs_cabby's Avatar
rs_cabby
you can use a s1 ecu on a s2 but not the other way round.
Old Oct 22, 2007 | 10:48 AM
SafeChav's Avatar
SafeChav
You can actually use a S2 ecu in a S1 aswell, but due to the fact the S1 doesn't have a knock sensor the ignition will run retarded, but its very easy to wire one in
What you're doing is absolutely fine though, just make sure you have the car set up so theres no chance of detonation!
Old Oct 22, 2007 | 11:09 AM
Ade's Avatar
Ade
Fast Ford snapper
Cool, thats good to know.
Change of plans for my MK3 so was going to just sell it as I doubt I'll ever buy an S1 in the future, but much more chance of buying an S2 so could be worth having.....
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
JK12
33
Apr 26, 2021 12:09 PM
A.t.p
Oct 23, 2015 07:54 PM
griffo69
Oct 4, 2015 11:58 AM
