S2 to S1 Gearbox end casing swap?
Old Oct 19, 2007 | 11:38 PM
Ade's Avatar
Ade
Fast Ford snapper
Default S2 to S1 Gearbox end casing swap?
How complicated is it?
Needing the Mk3 style mount.....
Is it easy enough to just unbolt the end casing and swap over that part, or is it a bit more involved than this?
Old Oct 20, 2007 | 09:52 AM
antony215's Avatar
antony215
Escort Rs Turbo
It's not that hard to do the hardest part is getting the 5th gear off so you can take the middle casing off you will need a gear puller to get that off so if you anit got one id get one or you will have a hell of a job trying to get it off theres a post in the Technical essay Archives about how to rebuild a gearbox that may help you out
Old Oct 20, 2007 | 11:59 AM
Ade's Avatar
Ade
Fast Ford snapper
shit
So it's not just like you can unbolt the end part case of one box and swap it over with another one?
Didn't think dealing with gears would be nessesary.... just wanna get the right end casing/bolt pattern for a MK3
Old Oct 20, 2007 | 12:06 PM
antony215's Avatar
antony215
Escort Rs Turbo
It's not that hard mate it sounds alot harder than it is. Like i say the hardest part is getting 5th gear off after that it's easy
Old Oct 20, 2007 | 12:17 PM
Ade's Avatar
Ade
Fast Ford snapper
So 5th gear is actually attached to the end casing, not just covered by it?
Old Oct 20, 2007 | 12:35 PM
antony215's Avatar
antony215
Escort Rs Turbo
It's not attached but you cant take the casings apart unless you take 5th off
This is a more detailed look at how to take it apart
http://www.quantums.info/gearbox.htm
Old Oct 20, 2007 | 12:41 PM
Ade's Avatar
Ade
Fast Ford snapper
cheers though
Old Oct 21, 2007 | 02:42 AM
wul young's Avatar
wul young
Originally Posted by Ade
cheers though
awright ade,drop it of to me or u can wait while i do it take hour max,ive done loads o them,just let me know m8.
Old Oct 21, 2007 | 05:08 PM
Ade's Avatar
Ade
Fast Ford snapper
cheers though
Nice one Wullie!
May well be in touch about that.....
Not entirely sure what gearbox route I'll be taking yet but one option I've got would require having to convert a S2 box to S1 style.
Old Oct 22, 2007 | 07:20 PM
wul young's Avatar
wul young
cheers though
Nice one Wullie!
no probs ade,just let me know if you need anything,got few broken 1b5@bc boxes lyin about to with slippers,we can build whatever you decide. or you could go mtx,depends what power your aiming for?
Old Oct 22, 2007 | 08:05 PM
Ade's Avatar
Ade
Fast Ford snapper
Cheers Wullie
I'm getting a 1900 CVH sorted just now... 300BHP at the fly is the figure that's being aimed for....
The hardest bit will most likely be finding a strong and cost effective gearbox solution.....
MTX is tempting and I may still go that way, but would rather keep this shell original as it's a good 'un... and we all know how hard they are to come by these days...
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
grishenko45
Sep 9, 2015 12:58 PM
gingeRS
Sep 4, 2015 06:29 PM
