1997 1.6 16v Zetec idling problem
Old Oct 19, 2007 | 10:03 PM
Dan Si's Avatar
Dan Si
Default 1997 1.6 16v Zetec idling problem
Hi Guys,
The 1.6 16v engine in my 1997 Escort Si has problems idling. When you start it up th revs float up and down between 500 and 1250 revs. I'll drive the car along, pull up at some lights, it'll idle fine for about thirty seconds and then the revs well float up and down again. Vibrations can be felt through the car. I've given the inlet a clean out and checked there are no blockages in the air filter system.
Do fords throw up dash lights when there is an electrical fault?
Dan
Old Oct 19, 2007 | 10:31 PM
djmillsy's Avatar
djmillsy
Fife Radge
check the idle control valve
Old Oct 20, 2007 | 02:58 PM
Yorkrst2's Avatar
Yorkrst2
Check the breather pipes on the inlet manifold, if you have an air leak it will cause the engine managament to go hey wire.
I had a simplar problem and changed the inlet maniford gasket and a cracked breather pipe, runs like a dream now.
Old Oct 26, 2007 | 09:03 PM
Dan Si's Avatar
Dan Si
Is the idle control valve a black box on the right hand side of where the air goes in?
Old Oct 26, 2007 | 10:42 PM
Dan Si's Avatar
Dan Si
I found this... http://www.ford-force.com/forums/ind...showtopic=3089
Maybe useful to other people too.
Old Oct 31, 2007 | 07:57 PM
djmillsy's Avatar
djmillsy
Fife Radge
did you get it sorted mate
Old Nov 3, 2007 | 11:49 PM
Dan Si's Avatar
Dan Si
Did it today mate. So far so good
Took two hours in total but really pleased with it now.
Old Nov 3, 2007 | 11:57 PM
djmillsy's Avatar
djmillsy
Fife Radge
15
Oct 7, 2015 03:43 PM
RSmark84
Sep 13, 2015 01:29 PM
Marino
Sep 12, 2015 11:10 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
