turbo repair/refurb
Old Oct 18, 2007 | 07:23 PM
trossnova's Avatar
trossnova
Default turbo repair/refurb
i have a t3 from an escort rst and the turbine shaft has play in it can i replace the bearings my self? any advice would be great cheers
Old Oct 19, 2007 | 04:03 PM
djmillsy's Avatar
djmillsy
Fife Radge
you can but youd be better getting it totally stripped down and rebuilt
Old Oct 19, 2007 | 10:13 PM
SafeChav's Avatar
SafeChav
A minor service kit won't necessarily be the answer.
if it was just smoking then yes it almost certainly would. because theres play in the shaft chances are the alloy back plate behind the compressor will be substantially worn meaning seals alone won't fix it.
You will probably also find the shaft is scored aswell.
Old Oct 20, 2007 | 12:19 PM
trossnova's Avatar
trossnova
i dont ohnistly know if it was smokeing as i got the turbo from a friend with an engine i bought that needs a complete overhall. the reason i know their is play in the shaft is cos i han move it with my hands
any idea how much to get it refurb by a company and where?
Old Oct 20, 2007 | 01:36 PM
SafeChav's Avatar
SafeChav
how much play are we talking.
All wet floating bearing turbos have a touch of play, but if you can get the compressor to foul the housing then generally its worn to excess.
A refurb is usually just an exchanged unit these days.
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
