My s2 resto(New wheels fitted)
Here are a few pics of how of my turbo used to look when i sparyed it black about 3years ago
Then i got abit pissed off with the stickers and the white wheels so i took the stickers off and painted the wheels silver
And then is this is what happened on way to a show 15 months ago
And here are some pics from the start of the re-build
When i brought this it was just a rolling shell as my frist rs turbo was rotton
,So i got this shell as it was the best i one i could find at the time but it was mercaury grey and i do not like that colour at all so as i paint cars all day as it my job i thought i would give it a nice black paint job but i have now got abit pissed of with black.
So the plans are as follows........
full body resto and the underside will be getting done as well
colour change
smooth engine bay (TWINS style
new wheels and they are 18's
adjustable tcas
engine rebuild
cosworth management
hi spec 330mm front brakes
cosworth rear brakes
new front wings and front panel
gaz coilovers
full poly bush kit
some new seats but unsure on which ones yet
full samco hose kit
and much more i hope
Here are some more pics, i have been working on the car for about 8-9 mouths now so i have lots of pics
started to remove some panels
Lots more pics to come
,So i got this shell as it was the best i one i could find at the time but it was mercaury grey and i do not like that colour at all so as i paint cars all day as it my job i thought i would give it a nice black paint job but i have now got abit pissed of with black. So the plans are as follows........
colour change
)new wheels and they are 18's
adjustable tcas
engine rebuild
cosworth management
gaz coilovers
full poly bush kit
full samco hose kit
Once i had got the panels off i got some of these from a shop near me for £2 pound each so i got 20 of them
and then it look like this
And then i found this hiding under alot of sealer
So i have got some new chassis for it now
Because of the rot on the chassis i did not want to weld plates on them so i got some new one's
Here are the new one's
So i took the old one's off
And then got busy welding the new one's in to place
hope you lot like and i am just up loading some more pics
After welding the chassis in i did not want to leave the underside of the car in bare metal for long so the next day i wiped the underside of with some thinners just to make sure there was no oil or grease left on it, Then i give it two coats of etch primer on it and then i left it for a few hours to go hard then i when and sealed up all of the joins were i had removed the sealer from
Then i left that for a day or two till my stone chip come as the pepole how we use at my work place did not have as much as what i need in stock so they had to order it for me from 3m,
this is the stone chip stuff that i am on about
the only thing is that it is about £15+vat
per bag and i used 16 bags on the car
thank god i got my works discount of it
And this is what it looks like
lots more pics to come let me now what us think
thank god i got my works discount of it And this is what it looks like
Right then i forgot to put these pics up they are from after i had etch primed but before i had stone chiped
the new wheels
new front panel and wings on and lined up to make sur of a good fit and the i weld them on when i was happy with the fit
i then removed all the springs from the car to see where the wheels would catch the arches so that i could remove the metal that was in the way
more pics to come soon
hope you like
the new wheels
hope you like
Originally Posted by craig rs
nice work, hmmm i wonder what car your copying
2. It's having a colour change
If you have nothing decent to say don't fucking say it,
Jamie what ya doin with the front end keeping it as is or going for something different mate??
Top work btw anymore pics
and the front end will look the same as be for but i am hoping to get a carbon bonnet and i will have two different front bumpers so i can change them when i get bored
but i got my ideas from this car
SOY r.i.p
right pepole some more pics
just before i weld the front end on i thought i would weld all the hole up in the engine bay and on the front panel (TWINS STYLE
) hope you do not think i am copying fella
and the front panel all done
front panel on and welded
all the inner wing filled and front panel
lots more to come
lots more to come
Originally Posted by Turbo Pez
Nice work matey, was your new chassis rails a arse to get on, cause mine are being a rite c*nt!
a few more
front wings welded on
and no pepole that blue is not the colour that the car will be i just seen it in my local paint shop and got a small bit just to see what it would look like
still lots more to come
Thanks for the comments pepole
no its not going to be that blue as it is a lot of money and its a pain in the arse to spray it cost me about £35 to paint that one wing as you have to paint it silver then you put that blue on and if the blue goes on a bit to wet in one place then you have to start it again
any way a few more pics for you lot
next step was to get some high build primer on the front end and on the boot tailgate for got to say i have removed the boot lock and rear wiper
and after 4 good coat it looked like this
and i put some on the underside of the front panel
still more to come
still more to come
What primer is that mate? Looks like a primer we use in work, Good quality high build ( cant remember the name
Started being the word here.. Making it to various shows is another
Originally Posted by puss
Actually young rad i think you will find mine was started before dave if you look at the dates
