Non turbo CVH to Turbo CVH
Old Oct 16, 2007 | 05:35 PM
cossy819's Avatar
cossy819
Default Non turbo CVH to Turbo CVH
As above was wondering what needs doing to the engine to make it into a turbo i know it will need the turbo and parts like that but it wqas more the block its self and bits like that im unsure of
Old Oct 16, 2007 | 06:05 PM
antony215's Avatar
antony215
Escort Rs Turbo
Different pistons( so you have the right c/r) the block will need a hole cut for the oil return for the turbo and oil feed for the turbo. it's works out alot easyer and cheaper to just get a turbo bottom end mate.
Old Oct 17, 2007 | 02:34 PM
SafeChav's Avatar
SafeChav
You can never make the oil return on a N/A block the same as a turbo block because the castings are different.
As above really for the price you can get a turbo motor for.
Old Oct 17, 2007 | 07:27 PM
cossy819's Avatar
cossy819
so how much am i looking at for just the engine and hoses i dont need anything else i have it already from when i was going to do a zetec turbo before i got rid of the car and got my cabby
Old Oct 17, 2007 | 08:06 PM
MarkN's Avatar
MarkN
No you can't get it exactly the same but you can get it working perfectly well - I know because I've done it
Old Oct 18, 2007 | 11:18 AM
cossy819's Avatar
cossy819
so it can be done if i get the oil return sorted out on the sump and get the correct rst pistons that would be the engine side sorted out? then its a case of bolting on the turbo and everything else?
Old Oct 18, 2007 | 02:10 PM
SafeChav's Avatar
SafeChav
"High ho Silver"
Old Oct 18, 2007 | 02:42 PM
markc's Avatar
markc
hows that running mark?
Old Oct 18, 2007 | 08:05 PM
MarkN's Avatar
MarkN
Running very well now thanks mate, despite what the lump hammer wielding Chav man says lol.
The conversion was quite easy really. I got a local engineering firm to drill the holes for the CPS and turbo oil return. Changed the pistons and voila - turbo CVH with the original engine number.
The only difference in the casting is that the turbo block has a proper drain internally, whereas if you have the hole drilled the oil will run down the inside of the block unless you get a "spout" arrangement fitted.
I would definately do this conversion again, its so much quicker than it was before
Old Oct 20, 2007 | 04:48 PM
cossy819's Avatar
cossy819
so would it be easier to swap the engine or get my wifes uncle who is a welder and very very handy with drilling stuff and that to weld me an oil return pipe on to the sump?
Old Oct 20, 2007 | 04:57 PM
antony215's Avatar
antony215
Escort Rs Turbo
It would be alot easyer and cheaper to get a turbo engine you can pick up a decent one for about £200-300. It will cost you more than that to build your own.
Old Oct 20, 2007 | 05:13 PM
cossy819's Avatar
cossy819
iv tried looking for one near to me the nearest i can find is over 150 miles away and i dont have a van or a means of picking it up (damn living in devon is crap)
Old Oct 22, 2007 | 09:05 AM
cossy819's Avatar
cossy819
been looking and cant find an engine close enough for me to get so i have no choice but to get the camshaft and pistons from a rst engine and fit them then get the oil return sorted out anything else i will need to do?
Old Oct 22, 2007 | 10:44 AM
SafeChav's Avatar
SafeChav
you can get a CVH in the back of most hatch back cars, could even get it in a saloon if you wanted to!
As for mileage ive never ONCE been able to find anything i need close to me, doing the miles seems inevitable.
JK12
33
Apr 26, 2021 12:09 PM
RSmark84
Sep 13, 2015 01:29 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
