Brake lines?
Old Oct 15, 2007 | 10:59 AM
GaryHurn's Avatar
GaryHurn
Default Brake lines?
hi i have a ford ka and have recently converted the car to run a willwood pedal set with remote resivours, only problme being is the one piece brake lines fitted would not screw into the goodridge brake lines i have conected to the calipers, so i was wanting to know where could i send the offending lines to have new unions fitted so they mate up! i cant bleed the brakes and i ve removed the old pedal set servo and master cylinder etc?
could i give goodridge a call?
gary
Old Oct 15, 2007 | 12:22 PM
Might be quicker to look in yellow pages under hydraulic pipes etc, and just have some made up.
Old Oct 16, 2007 | 07:36 AM
Aaroncast's Avatar
Aaroncast
ive always made my own up for track cars etc-go to burtons site and see goodridge unions/-3 hose / you must know your thread of course metric 'not' af as you must have a newer car-yes?.
feeling confident braking from 150mph-ish??
NO?---- get them made up then
