sierra cosworth ECU plug
Old Oct 13, 2007 | 05:06 PM
tribal jedi's Avatar
tribal jedi
Default sierra cosworth ECU plug
Can anyone help,i need to know the wire colours for the ECU plug found behind the dash. the plug has numbers written on either side. NUMBER 10 ,28 ,4. at the moment these 3 are all black as it is rigged to my vecta immobiliser. but need to know the original colours to bypass this to make it start after it was wrecked by scum the other night!!!
Old Oct 14, 2007 | 11:06 AM
COLEYST200's Avatar
COLEYST200
I mate iv got a very simler problem with my 3DR LOOM drop this man a line he is going to sort my loom out for me . carloomsuk@hotmail.com hi name is Ryan 07919537128
Old Oct 14, 2007 | 11:48 AM
Ryan's Avatar
Ryan
10 - ecu pump relay earth trigger
28 - fuel pump relay earth trigger
3- crank sensor signal
4 - crank sensor ground
Old Oct 14, 2007 | 02:15 PM
You can get looms at least as good but a cheaper than ryan's.
Old Oct 14, 2007 | 06:26 PM
Ryan's Avatar
Ryan
prey tell then tabetha, saves me making them then, if there like 200 and just as good quality as mine.
come on then? do tell?
Old Oct 14, 2007 | 06:59 PM
tribal jedi
cheers for that ryan, just realised your in our hants owners club
Old Oct 14, 2007 | 09:43 PM
Ryan's Avatar
Ryan
yes mate i'll be at the meeting tommorrow night, ask someone to point me out if you need to chat to me mate
Old Oct 15, 2007 | 05:08 AM
My friend is making one for Nash at the moment, he is very experienced at all levels of motorsport in making looms, qulaity is ace but he wants to go through a third party, as he does not want people turning up at his house/work place.
If you want a quote I can certainly get you one, he has only very recently started doing cossie looms, so recently in fact he is still doing the first one!!
He has done loads of course but these were mostly one off looms, and for some very big names, who he still does them for, but the work is a bit seasonal, so filling time to get some pennies by doing other ones.
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
martynhomer01
16
Aug 4, 2015 09:55 PM
