1800 zetec and bike carbs ?
If you are going to the hassle of fitting bike carbs then fit bike throttle bodies
They are easier to set up, give smoother power etc. You will need an ECU wether you use carbs or TBs so you might as well fuel inject. Also, if you car is newer than 93 you will not pass the MOT with carbs.
mk3ste
Oct 17, 2021 10:09 AM
sridgett
Oct 1, 2015 07:30 PM
Orion_Gav
Sep 29, 2015 04:50 PM
