P8,10cd Chgr,inj's,exhaust man,clutch,act'r,Fuel pump
Rubber Rhino Crew
P8 ECU, good condition swapped with Pieterjan on here for a S8 few months back, ..now not needed for my plans so for sale. Aircon model with unknown chip. £300
Sony 10 CD changer unit + steering controls (for suitable headunit) £25
Std blue sapphy injectors, working fine. £30
4x4 Exhaust manifold w/crack in usual place not blowing £30
Stage 1 Organic clutch plate (AP) did 500 miles in car and not even worn paint markings off of pad material yet. So this is AS NEW condition and was used with a STD ford cover same as AP supply in full kit so grab a bargain and use a std cover or your existing cover with this plate. Good alternative to paddle clutch. £50
Std cossie 4x4 actuator £10
Std cossie fuel pump £20
2wd Engine loom, good working fine condition just needs a couple of metal clips that hold plugs onto coolant temp sensor...lost a few removing it. £30
Postage Extra or may swap or p/x above item(s) for a set of 17+ inch compo's, polly bushes, Intercooler (pm me with what you have).
kosienutter
31
Aug 22, 2015 09:55 AM
