clock wiring
Old Oct 7, 2007 | 04:36 PM
dkmk4's Avatar
dkmk4
Default clock wiring
any 1 on the swansea ares that could wire my s2 clocks into a mk4 escort non turbo or has any 1 got a wiring diagram or pin numbers??
Old Oct 8, 2007 | 10:17 AM
Aaroncast's Avatar
Aaroncast
workshop manuals on e bay £250 ish showing all wiring etc ive got one and it is excellent--for s1 and s2
Old Oct 8, 2007 | 09:57 PM
dkmk4's Avatar
dkmk4
£250
Old Oct 9, 2007 | 09:08 AM
IANS2RST's Avatar
IANS2RST
did you get the wiring plugs that fit in the back of the clocks?
if so cut you old plugs off & match all the colours up, you should be left with a single green wire coming from the plug on the clocks. connect this to the negative side of the coil which is also a green wire
speedo connection is the same
Old Oct 9, 2007 | 12:32 PM
SafeChav's Avatar
SafeChav
I think you'll find your an earth wire short and theres a redundant permentant 12v feed aswell!
Old Oct 9, 2007 | 12:53 PM
IANS2RST's Avatar
IANS2RST
been a while since I messed with an rst
Old Oct 9, 2007 | 05:51 PM
dkmk4's Avatar
dkmk4
can any 1 do it for me im starting to get v.lost
Old Oct 11, 2007 | 01:49 PM
SafeChav's Avatar
SafeChav
how much £$£$£$£$£
Old Oct 12, 2007 | 01:19 PM
dkmk4's Avatar
dkmk4
rite gunna have a go myself on the both clocks there are 2 clips would the wail from both clips go to the same clips on the other side?
Old Oct 12, 2007 | 06:41 PM
SafeChav's Avatar
SafeChav
the what
Old Oct 13, 2007 | 01:04 PM
dkmk4's Avatar
dkmk4
nevery mind lol on some clocks the petrol gauge and tem are diff way round (left to right) (right to left) are the wirs the same??
Old Oct 14, 2007 | 11:19 AM
SafeChav's Avatar
SafeChav
wires themselves are the same but the order in the plug varies between pre 90 spec and 90 spec
Old Oct 14, 2007 | 08:40 PM
dkmk4's Avatar
dkmk4
ok thanks
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Mr S1
20
Sep 27, 2015 04:06 PM
