ABS Sensors Wiring
Old Oct 3, 2007 | 07:14 PM
Shonky's Avatar
Shonky
V6 Ka of Love
Default ABS Sensors Wiring
Hi, I've got a KA front hub with ABS sensor built in for a conversion, I'm not running the whole ABS unit but need to use the sensor to get the wheel speed signal, the sensor has two pins in the plug, I assume the body is earthed so the two pins are power and signal, is this correct? which pin is which?
Thanks
muzzman1
Sep 30, 2015 08:59 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
Si B
Sep 12, 2015 06:49 AM
