who has wasted spark fitted?
yh im thinking about it aswel mate..
gota send my ecu back to stu anyway, as getting a new chip written
, so thing to go wasted spark aswel..
but not really sure what the advantages are
, so thing to go wasted spark aswel..but not really sure what the advantages are
Piece of cake to fit, some small amount of delicate soldering, other bits to fit are easy, msd website contains all bits needed.
Will give a much better spark under higher boost which is why it was developed to start with, for cars where spark was getting blown out.
The distributor cap, rotor arm, Coil HT lead and Standard Coil are removed from the car totally leaving you with a solid state non moving HT ignition system with less HT connections and only 1 gap for the voltage to jump, the all important spark plug gap.
so i guess that means YES
yes
as you seem to have the link are you bored.
you seem to know the info already
http://www.motorsport-developments.c.../iawwasted.htm
so why ask
so why ask
Escortdriver1
Aug 19, 2015 09:02 PM
cozzy jeff
Aug 14, 2015 05:46 PM
Escortdriver1
Jul 31, 2015 02:36 PM
