rs turbo gearbox advice
Old Oct 2, 2007 | 09:07 PM
10th_racer's Avatar
10th_racer
Default rs turbo gearbox advice
hi guys, bit of help needed.
basically, rst lump going in my ka, want a s2 box for the LSD, want a S1 box as its got the mount on the front so would save having to make up another mount.
have found a nice S1 gearbox case for sale so was planning on buying that, then also buying a S2 LSD box and putting all the bits from the s2 box in the s1 case, will all this fit alright? is it just a straight swap?
thanks,
ben.
Old Oct 3, 2007 | 12:47 AM
Nick.'s Avatar
Nick.
Hi ben
Couldn't you get a S1 box already built up.. remove the existing LSD from it and then replace it with the improved LSD fitted to the Series 2 box?
Nick.. oh and ill bring you that battery round tomorrow all charged up
Old Oct 3, 2007 | 07:54 PM
10th_racer's Avatar
10th_racer
but if i buy a s1 box already built i'd only strip it and probly end up having the case powdercoated anyway so would be easier to buy this one already done.
s1's didnt have LSD's anyway did they? only s2?
Old Oct 3, 2007 | 09:18 PM
turnpike500's Avatar
turnpike500
hi, its quite staight forward to swap the casing, but you will need a puller for 5th gear. some experience with this box would be usefull though.
Old Oct 3, 2007 | 10:33 PM
Nick.'s Avatar
Nick.
Yeah s1 has an viscous controlled LSD... the S2 just had an improved version of it
Nick
Old Oct 5, 2007 | 07:34 PM
JesseT's Avatar
JesseT
Nick
Where do you base this? Common information is that the S2 had the downgraded LSD.
Old Oct 5, 2007 | 11:16 PM
Nick.'s Avatar
Nick.
Rs owners club website.. in the list of what was changed between the S1 & S2
http://www.rsownersclub.co.uk/car_info/esc4rsts2.htm
Old Oct 6, 2007 | 12:41 PM
JesseT's Avatar
JesseT
Ha!
Well, it also states that the intercooler, KE-jetronic and gearbox are improved
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
knight19770
Aug 4, 2015 12:36 PM
