Changing track rod end on mk6 escort. easy/hard?
Old Oct 2, 2007 | 06:32 AM
c.h.r.i.s's Avatar
c.h.r.i.s
Default Changing track rod end on mk6 escort. easy/hard?
Need to do the right hand side one on my car later. Its the first one ive done so whats the best way of going about it?
Thanks
Chris
Old Oct 2, 2007 | 06:36 AM
edd's Avatar
edd
blowtorch, socket set, allen key set and a mallet. undo the nut beat the fuck out of it (not the thread the round bit the joint goes through) till the balljoint pops out then unscrew it off the steering arm if it aint seized to fuck.
fit new one roughly then get the tracking done.
Old Oct 2, 2007 | 10:20 AM
trig_112's Avatar
trig_112
undo the locking nut on the steering rod firsy, drown it in penetrating oil, if its not been undone in a while then drown it again, put a spanner on it and hit it hard to undo.
then undo the track rod end nut in the hub and hit it upwards, once again hard.
The hammer is an instrumental tool in this operation.
Old Oct 2, 2007 | 10:22 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
good luck
Old Oct 2, 2007 | 10:43 AM
c.h.r.i.s's Avatar
c.h.r.i.s
thanks guys. Sounds like fun
Old Oct 2, 2007 | 10:49 AM
trig_112's Avatar
trig_112
if your idea of fun is lots of scraped knuckles, bits of skin attatched to your car, solvent in the wounds and a bent spanner, then you are in for a whale of a time.
the blowtorch comes in handy if you have one
Old Oct 2, 2007 | 10:54 AM
JamesH's Avatar
JamesH
Old Oct 2, 2007 | 08:58 PM
c.h.r.i.s's Avatar
c.h.r.i.s
trig_112
Its not that bad ! I enjoyed it so much that i also changed the lower arm on the other side because the fucked track rod end wasnt the only problem
So in the 6 months ive owned it it has had 3 different lower arms on the nearside and 2 on the offside
Atleast its sorted. Till next time stupid cars
FlashRS
13
Aug 31, 2015 06:02 PM
cameron2
Aug 25, 2015 07:18 AM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
Lee Reynolds
85
Aug 10, 2015 05:56 PM
