had my saph on the roller's other day..304 bhp
Old Oct 2, 2007 | 02:55 AM
R5FORD's Avatar
R5FORD
Default had my saph on the roller's other day..304 bhp
with graph aswell..im very happy with how it goes..
304 atw
car gave me a bloody nightmare for the last 3 months but that blast past a scooby was well worth it..he even stoped to say very nice mate very nice indeed
Old Oct 2, 2007 | 03:24 AM
4x4's Avatar
4x4
R5FORD
how comes it says RS500 on the print out.... fookin aussies
Old Oct 2, 2007 | 03:28 AM
R5FORD's Avatar
R5FORD
yh and i told him to change it but noo still did it second round time
Old Oct 2, 2007 | 06:39 AM
R5FORD's Avatar
R5FORD
no one cares
Old Oct 2, 2007 | 06:45 AM
Vic's Avatar
Vic
cool ...
how did you go with the compressor surge issues?
Is that at 24 psi?
Old Oct 2, 2007 | 06:47 AM
R5FORD's Avatar
R5FORD
peaking at 23..holding 22 mate..
boost was going to be up'd a lil but the injectors were maxing out..
still got that stupid flutter..made sure theres no air likes so not really sure what it is
Old Oct 2, 2007 | 06:49 AM
Looks good that does, bit odd seeing KW!!
We are still in old language in the uk.
Old Oct 2, 2007 | 06:50 AM
R5FORD's Avatar
R5FORD
cheers mate
well pleased with it..
yh and in the uk they still use fly wheel figures
Old Oct 2, 2007 | 07:01 AM
The rollers I use give out both wheels and flywheel, using coast down, I am never bothered about the power anyway, just the torque curve and afr/boost.
Old Oct 2, 2007 | 07:03 AM
Bullett's Avatar
Bullett
well done mate,
Old Oct 2, 2007 | 07:12 AM
R5FORD's Avatar
R5FORD
cheers bullet..been a long road but got there in the end..a urge for more power is on the verge
Old Oct 2, 2007 | 07:39 AM
Bullett's Avatar
Bullett
always will be buddy.i remember when harvey stg 3'd mine from standard.he came back chucked me the keys and said go on see what you think.i took it gave it a pasting,came back and said yeah goes well but it aint quick enough for me. all he said was "cunt, it never will be"
Old Oct 2, 2007 | 08:20 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
IT'S SURGE - how many more times do you want telling ?
Old Oct 2, 2007 | 08:52 AM
KSA-Cossie's Avatar
KSA-Cossie
2 more at the wheels than me , good power though m8.
Old Oct 2, 2007 | 10:39 AM
R5FORD's Avatar
R5FORD
mike how many more times you want to tell me lol
ksa cossie..would be down to has the heavier right foot out of me and you then your car looks better tho
Old Oct 2, 2007 | 11:00 AM
Dan's Avatar
Dan
Nice power mate! I did wonder when it said 'RS500' on the graph! lol
Old Oct 2, 2007 | 11:04 AM
R5FORD's Avatar
R5FORD
yh he just put that down..out here they think its the only cosworth..dont really know about the saphs
Old Oct 2, 2007 | 11:07 AM
KSA-Cossie's Avatar
KSA-Cossie
Was yours being tuned or just a power run.
Old Oct 2, 2007 | 12:00 PM
R5FORD's Avatar
R5FORD
tuned mate..gone from stage 1 to stage 3 with a t34.48 that blew up..now gone for a roller bearing turbo
Old Oct 2, 2007 | 12:01 PM
KSA-Cossie's Avatar
KSA-Cossie
Cool,mine was just a power run still needs a good set up.
Old Oct 2, 2007 | 12:06 PM
R5FORD's Avatar
R5FORD
mine needs more boost but injectors were reaching there limits i think..
think i need light blues and aroud 400bhp? lol
Old Oct 2, 2007 | 12:08 PM
KSA-Cossie's Avatar
KSA-Cossie
Are you on dark greens?
Old Oct 2, 2007 | 12:10 PM
R5FORD's Avatar
R5FORD
yhep dark greens mate
Old Oct 2, 2007 | 12:37 PM
KSA-Cossie's Avatar
KSA-Cossie
And they're maxed out ? I'm gonna run more boost with mine .
Old Oct 2, 2007 | 02:24 PM
JjCoDeX75's Avatar
JjCoDeX75
Nice little setup mate.
What turbo?
JJ
Old Oct 2, 2007 | 02:28 PM
CharlieSaff's Avatar
CharlieSaff
Kev,
When karl set my car up, he said it's now 350BHP give or take 5 each way. Same for torque!!
He also commented about how he wouldn't want to push them anymore and that if I wanted a bit more power then come back when I'd re-wired the fuel pump, fitted an 044 Group A pump, and got a set of greys
Re-wired the fuel pump just to air on the side of safety, I'm perfectly happy with the car now though
Old Oct 2, 2007 | 02:29 PM
KSA-Cossie's Avatar
KSA-Cossie
I've rewired the pump wiring and fitted an 044 pump charlie.
Old Oct 2, 2007 | 02:31 PM
CharlieSaff
I think it was more the green injectors that he was refering to that he didn't want to push anymore
Old Oct 2, 2007 | 02:33 PM
KSA-Cossie's Avatar
KSA-Cossie
Strange,cos when we were checking the afr it was quite rich top end Stu at MSD said if i had the fuel it would be ok.
Old Oct 2, 2007 | 02:37 PM
CharlieSaff
What exhaust housing do you have mate?
I've got the .63 and this maxes the greens out more than the .48 and .55 due to more air...
Mine runs a 28psi spike then down to 25/26ish then eventually goes down to 22psi for the limiter
Old Oct 2, 2007 | 02:41 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Cool
Old Oct 2, 2007 | 02:42 PM
KSA-Cossie's Avatar
KSA-Cossie
Got a .48 housing m8,spikes at 26 and tails off to about 21 psi.
Old Oct 2, 2007 | 02:43 PM
JjCoDeX75's Avatar
JjCoDeX75
Quite similar to Karls gunship conversion then. I for one wouldnt want to run any more boost than that on Greens with a 0.63.
Mine runs on the Siemens 550cc injectors with about 30psi peak, and a 26 psi hold, which works very well
JJ
Old Oct 2, 2007 | 02:48 PM
CharlieSaff
JJ
I know I wouldn't want to either It's top notch to drive though
Old Oct 2, 2007 | 02:49 PM
JjCoDeX75's Avatar
JjCoDeX75
JJ
Sounds good mate! Mind you - are you getting the best out of your 0.63? You would be amazed at the difference of the extra couple of psi at the upper end if nicely mapped.
JJ
Old Oct 2, 2007 | 03:14 PM
CharlieSaff
JJ
JJ
Problem not, and Karl did mention this as well, I wish he'd told me before I went to see him and I'd have bought some greys first
Mind you, before I took it to him I'd only just rebuilt the engine (I'd ran it in for about 1200 miles) and it was only running 19psi, so initially it was mega with a 28psi spike and 26psi held for most of the rev range
Still is quick too IMO
Old Oct 2, 2007 | 03:16 PM
KSA-Cossie's Avatar
KSA-Cossie
How does karl manage to only lose 2psi from the spike ? Mine tails off 5psi .
Old Oct 2, 2007 | 03:20 PM
CharlieSaff
My mistake, just found where I wrote about it at the time
Boosts upto 1.9BAR (27.55psi) upto 5000 rpm, then drops to 23-24psi for 6000rpm, and then tails to (22psi) for the limiter to 7250rpm.
Old Oct 2, 2007 | 03:26 PM
KSA-Cossie's Avatar
KSA-Cossie
Didn't notice that myself lol.
JjCoDeX75's Avatar
JjCoDeX75
This can also depend on the boost controller as well as the turbo - often the turbo is not the weak link
JJ
