Air to Air
Old Oct 2, 2007 | 01:17 AM
JonnyBravo's Avatar
JonnyBravo
Default Air to Air
Whilst having a conversation with a mate of mine earlier about air injectors it seems I haven't quite understood what I was originally told about them.
I was under the impression that one thing you could gain was faster response from the turbo.
I've just read Stu's article on it but it doesn't really go that deeply into it.
What exactly is the advantages from using them ?
Old Oct 2, 2007 | 01:27 AM
PhilM's Avatar
PhilM
PassionBMW.com Member
They are just used as a method of controlling the turbo's wastegate, pressure usually goes from the compressor to the actuator direct/though an amal valve.
All air injectors do is allow fine control of the pressure getting to the wastegate actuator, allowing you to really control/map your boost.
Old Oct 2, 2007 | 01:36 AM
JonnyBravo's Avatar
JonnyBravo
I think tiredness is a key factor here
After just having another read I can see the gains to be had when setting the boost, I was under the impression that there was gains to be had getting the turbo onto boost but when thinking about it there is no other way of doing that than changing the turbo housings (or anti lag etc..)
answered my own question tbh
Old Oct 2, 2007 | 05:08 AM
GARETH T's Avatar
GARETH T
the wastegate actuator wont creap with a bleed on system (air to air) so the wastegate is bypassing any air, so the turbine housing gets it the exhaust flow through it
with a bleed off system (amal) the wastegate can start to creep as pressure in building in the compressor site, slightly lifting the wastegate, slightly reducing the amount of flow which is flowing through the turbine housing
Old Oct 2, 2007 | 07:26 AM
JonnyBravo's Avatar
JonnyBravo
Cheers Gareth
Old Oct 2, 2007 | 07:40 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
However, you can STILL get boost creep if the turbo's wastegate isn't of suficient size to allow sufficient bleed off when fully open, so don't expect it to be a miricale cure for T4s, which must have the largest wastegate penny and even be gas flowed to enable boost creep to be eliminated. As has been said, all air injectors will do is give more accurate boost control. Only problem is if they fail, then you get unlimited boost .
Old Oct 2, 2007 | 09:33 AM
JonnyBravo's Avatar
JonnyBravo
What do you use on yours Mike ?
Old Oct 2, 2007 | 09:37 AM
Mike Rainbird
Caraholic
Genuine Ford Motorsport air injectors.
Old Oct 2, 2007 | 09:40 AM
JonnyBravo's Avatar
JonnyBravo
Yeh I have the same but obviously haven't got round to using them yet
Old Oct 2, 2007 | 10:38 AM
Markb_s1's Avatar
Markb_s1
problem that's always struck me with air injectors is that surely, they don't fail safe.... i.e. in the event of failure the boost goes sky high with the inevitable problems that can cause...
Old Oct 2, 2007 | 10:45 AM
JonnyBravo's Avatar
JonnyBravo
That is true but tbh it happens rarely and I suppose if you know your car well enough you will catch it before it blows itself to bits.
I am starting to swing towards using AVCR though for the in gear boost control
Old Oct 2, 2007 | 02:43 PM
GARETH T's Avatar
GARETH T
i havent talked about boost creep
Brickhouse
14
Oct 3, 2015 07:28 PM
fordrallycar
Sep 30, 2015 07:57 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
