Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Escort 1.6 si [ idle problems ]
Old Oct 1, 2007 | 07:58 PM
smegs's Avatar
smegs
Default Escort 1.6 si [ idle problems ]
Hi
I have just bought a R Reg 1.6si and it seems to have some sort of idle problems ! when i first get in it in the morning it starts as normal [sometimes sounds as if its going to die but doesnt ] , then as soon as i drive off its like the throttle sticks and goes up to about 3000rpm so i put my foot on the clutch and it goes up a little more but quickly drops back to normal from what i can make out as it starts to warm up its fine , but if i stop for say half hour it does it all over again .
Any help or suggestions would be great
Many thanks
Old Oct 2, 2007 | 12:23 AM
Wardy257's Avatar
Wardy257
A common problem is a dirty ICSV. I would give the ISCV and the inside of the MAF a clean with carb cleaner.
Old Oct 3, 2007 | 06:04 AM
As wardy says then check co/lamda reading.
Old Oct 11, 2007 | 04:24 PM
jonboytechie's Avatar
jonboytechie
Thats definitely the ISCV mate - sits underneath the throttle boddy (attached to inlet manifold at the back)
They are Ł90 ish brand new from Ford so try and clean yours first if possible. Sounds like the runner rail inside is full of crap. Clean with Carb cleaner (the none residue type i.e. Wynns). Once you are happy its clean, throw it back on and start her up. If it doesnt fix it by cleaning then its a new ISCV mate.
Old Oct 24, 2007 | 07:27 PM
NateDawg's Avatar
NateDawg
i have the same problem with my 1.6 si just bout to ask bout it nice 1
Old Oct 26, 2007 | 05:25 PM
Dan Si's Avatar
Dan Si
Does the ISCV look like a black box on the right hand side of where the air goes in?
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
