Replacing broken bodykit clips on saph cossies
Old Oct 1, 2007 | 02:14 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Replacing broken bodykit clips on saph cossies
Anyone done it as am sick of the 5 quid clips breaking when you fit the fuckers.
Old Oct 1, 2007 | 02:16 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
Think i saw some genuine ones for sale on cosworthshop.com. Could be mistaken and RST ones though.
Whatever they probably want stupid money
Old Oct 1, 2007 | 02:17 PM
KSA-Cossie's Avatar
KSA-Cossie
Yeah but they break too fucking easy m8.
gwynny's Avatar
gwynny
I need to do mine, would like to see a pic of an alternative method.
Old Oct 1, 2007 | 02:18 PM
KSA-Cossie's Avatar
KSA-Cossie
Me too pal.
Old Oct 1, 2007 | 02:30 PM
COMEDY DAN's Avatar
COMEDY DAN
No1 Blower.
Some little aluminium ones would do the trick, I rekon there is a good market for someone to make a batch.
Old Oct 1, 2007 | 09:16 PM
CosKev3's Avatar
CosKev3
Done exactly that on mine
Some thin alloy from my old kitchen,bent into 'L' shape
Old Oct 2, 2007 | 09:02 AM
KSA-Cossie's Avatar
KSA-Cossie
How did you fix them to the sill ?
Old Oct 2, 2007 | 09:09 AM
The DIVA's Avatar
The DIVA
I made some a while ago from proper alloy extrusions.....
Did keep the drawings so might make some more in the future...
Old Oct 2, 2007 | 09:16 AM
KSA-Cossie's Avatar
KSA-Cossie
I'll have a set if you do m8.
Old Oct 2, 2007 | 09:21 AM
Rossco's Avatar
Rossco
Yep dont waste your money on new ones, they are shite!
I left the broken ones on and put a bit of Tigerseal on each clip, wedged a bit of wood under the skirt to hold it up when it was drying, next day jobs done.
Old Oct 2, 2007 | 09:22 AM
COMEDY DAN's Avatar
COMEDY DAN
No1 Blower.
Me is full of the best ideas.
Old Oct 2, 2007 | 09:57 AM
Jim Galbally's Avatar
Jim Galbally
i tried SOOOOO many methods, and i settled on...
drill and small cableties
SO SIMPLE, and you can't tell either
Old Oct 2, 2007 | 10:31 AM
Dan's Avatar
Dan
I'm getting some made in metal
The ones on Ebay are about £90! Sod that!
Old Oct 2, 2007 | 10:57 AM
foreigneRS's Avatar
foreigneRS
Testing the future
there's a post about getting these remade in the Sierra room
https://passionford.com/forum/viewtopic.php?t=251730
Old Oct 2, 2007 | 11:00 AM
Mark_w's Avatar
Mark_w
I would not reccomend buying the ones from ebay as i recently tried fitting some and half broke while doing it I believe that the plastic on these so called new ones has gone brittle over time and i tried heating them up,but to no avail,as i regularly find bits of them under my car in the garage
I am going to make some stainless ones soon as i reckon that they will be better than alloy,with a stainless screw to fix to body and a pop rivet to the plastic.
regards mark
Old Oct 2, 2007 | 07:24 PM
CosKev3's Avatar
CosKev3
Self tapper into sill lip,pop rivet onto skirts
regards mark
Why do you need to make them out of stainless hardly any weight on them.
Thin alloy was easy,can bend/adjuds them when your under car to get perfect
Old Oct 2, 2007 | 07:27 PM
KSA-Cossie's Avatar
KSA-Cossie
Plenty galv sheets at work will get one of the welders to make me some.
Old Oct 2, 2007 | 07:29 PM
Mark_w's Avatar
Mark_w
regards mark
They will be better made out of 1.2mm stainless strip for a few reasons...stronger,will never rust or deteriate and will not react like alloy does with steel and water.But that is just my opinion and how i want to do it
mark
DixieTheKid
Jul 23, 2023 10:16 AM
j.hammond1
30
Oct 31, 2021 05:28 PM
joe1979
Aug 26, 2015 05:08 PM
lukeeboy149
Aug 22, 2015 04:29 PM
gcfcos
118
Aug 18, 2015 05:53 PM
