Can you run a/f/r gauge off existing lambda sensor (4x4 saph
Old Oct 1, 2007 | 09:16 AM
KSA-Cossie's Avatar
KSA-Cossie
Default Can you run a/f/r gauge off existing lambda sensor (4x4 saph
And how do you do it if you can , also which gauge to use ?
Old Oct 1, 2007 | 09:26 AM
Jim Galbally's Avatar
Jim Galbally
std sensors are narrowband, totally not worth using for AFR monitoring
Old Oct 1, 2007 | 09:30 AM
KSA-Cossie's Avatar
KSA-Cossie
So wideband then jim ? Does stu sell em ?
Old Oct 1, 2007 | 09:53 AM
foreigneRS's Avatar
foreigneRS
Testing the future
with a wideband sensor and controller, you can have a simulated narrow band output so that you can connect it to your ecu for normal closed loop running
DixieTheKid
Jul 23, 2023 10:16 AM
Anutternutter
24
Aug 31, 2015 01:24 PM
Dahl88
Aug 22, 2015 08:16 PM
mrmann
Aug 20, 2015 11:24 PM
