saph cos 4*4 spongy brakes
Old Oct 1, 2007 | 01:34 AM
SS1's Avatar
SS1
Default saph cos 4*4 spongy brakes
spongy brake pedal
if i hit the pedal hard brakes lock on.
but a slow press some times the pedal just slowly sinks down. and i lose the bite unless i hit the pedal again.
the cars has goodridge stainless braided brake hoses 6 piece kit
Front brakes:
AP Racing 4-Pot Calipers with 330mm grooved AP discs
Rear brakes:
305mm vented disk conversion
Ferrodo Ds2500 pads all round
no apparent loss of brake fluid anywhere
ideas
Old Oct 1, 2007 | 08:22 AM
rsnissan's Avatar
rsnissan
When did you change the fluid last?? has this been a gradual thing or did it just start to feel like this recently?
Old Oct 2, 2007 | 09:40 PM
SS1's Avatar
SS1
rsnissan
sozz for late reply.its been a gradual thing since the hoses where fitted and i asked the garage to fully flush the system with 4dot fluid
i hope they did,the BILL was large enough < real tears
Old Oct 2, 2007 | 09:41 PM
KSA-Cossie's Avatar
KSA-Cossie
They didn't bleed the brakes right then m8,take it back.
Old Oct 2, 2007 | 09:42 PM
The DIVA's Avatar
The DIVA
Still air in the system then Steve...
Old Oct 2, 2007 | 09:56 PM
SS1's Avatar
SS1
it would appear so robbie
i was going to change the pads last sunday.then remembered had no copper grease for back of the pads.and all the motor factors where shut by 3pm
as the front calipers have two bleed nipples on each pair. is there a preferance which one inside or out to bleed first
Old Oct 2, 2007 | 10:04 PM
The DIVA's Avatar
The DIVA
I usually do the outer first and then the inner.....
If you get stuck mate,give us a shout.......you can always nip up and i`ll sort it for you...
Old Oct 2, 2007 | 10:07 PM
SS1's Avatar
SS1
your a star. cheers...
Old Oct 3, 2007 | 06:45 AM
I never use copper grease on the back of the pads, or the sepertately supplied anti rattle shims, I have yet to have any noise at all from them either.
It does sound like air in there still, I never bother on any car with order as I personally have never found it made any difference at all.
Old Oct 3, 2007 | 07:24 AM
wimwerf's Avatar
wimwerf
I had this to when i putted my AP's on my 4wd saph...turned out my wheel bearings where slightly worn...
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
