FAO MikeR- Flamer kit wires- what to where? UPDATE! Mike!
Old Sep 30, 2007 | 08:27 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default FAO MikeR- Flamer kit wires- what to where? UPDATE! Mike!
Yeahyeah, they gay, but ive just had a hunt around the house and found FOUR, yes FOUR of them
1st one is a MikeR original that I had on my Cossie, it has 4 wires.
White, Brown, Yellow, Blue.
What goes where?
Others have 5 wires tho and are all brand new, fuck knows about them, anyone know? Im guessing they them gay ones that cut the ignition or summat?
Old Sep 30, 2007 | 08:33 PM
Dan's Avatar
Dan
Fuck knows where they go but I might have one off ya!
Old Sep 30, 2007 | 08:37 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
May as fucking well, LOADS of people have em fitted and just dont admit it
And on that note, its NOT going on the Chaser, honest
And frankly its far lower on the gay scale than the other thing I got for it the other day that I dont care to mention either
Anyhow, MikeR etc- what wire goes where?!
Old Sep 30, 2007 | 08:39 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Let me buy one!!!!! PLEASE, gay as fuck or not, I dont care...
I got a gay image anyway
Old Sep 30, 2007 | 08:41 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
one of the kits is a TWIN one, to run 2 coils and 2 plugs if you got twin exhausts etc too, think might keep that for whenever i get round to finishing the v8
Old Sep 30, 2007 | 08:42 PM
CosKev3's Avatar
CosKev3
Funny colours on the wires
Got to be live,earth and then + to coil,and - to coil.
Unsure what the five wire ones do,could well be like you think,ign cut
Old Sep 30, 2007 | 08:43 PM
Charlie Chalk
Unknown.
Steve, sell me one!
Old Sep 30, 2007 | 08:52 PM
Dan's Avatar
Dan
Steve, sell me one!
Me too!
I couldn't give a fuck what people think, least of all the people on here!
Old Sep 30, 2007 | 08:53 PM
ECU Monitor Enthusiast
Steve,
I have a long peice of string here that you cant see.
How long is it please ?
Old Sep 30, 2007 | 08:55 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
fuck the 5 wire ones, ill use the original if it still works, its about 5years old now!
going by wire lengths i reckon white is power, brown makes sense to be earth, and the other 2 goes to the coil, which way round i dont know tho.
well, dunno if it matters?
Originally Posted by Flux Capacitor
Steve,
What you on about you mong, i bet mike R or anyone else with them can tell me what goes where.
Old Sep 30, 2007 | 08:57 PM
GARETH T's Avatar
GARETH T
what did you buy the other day then for teh chaser? and was it from halfords?
Old Sep 30, 2007 | 08:59 PM
PT's Avatar
PT
What, its going on the beemer
Old Oct 1, 2007 | 11:21 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
BTTT for manz liek Rainbum or anyone else who knows
Old Oct 1, 2007 | 12:26 PM
Micky's Avatar
Micky
Mine is as follows
Blue .. Negative ground
Red ..To ignition positve
Yellow... To coil negative
Thinner Red.... To coil positive
Slightly different colours,but may help you.Regards,Micky
Old Oct 1, 2007 | 12:29 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Originally Posted by Micky
Mine is as follows
Hmm, mine is 2001-2002 sort of spec so maybe he used different wires back then.
Maybe i can guess, im pretty sure I know the 2, just the coil ones I dont.
Will anything bad happen if i put coil ones wrong way round? As if all that happens is stuff dont work, its fine.
Old Oct 1, 2007 | 12:30 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
This sounds like an old one so the colours are not what we use now...
Can they test for continuity between white and yellow - should be short circuit?
If so then colours are as follows
Brown - Ground
Blue - Coil +
Yellow - Coil -
White - 12 v via 5a fuse and switch
Old Oct 1, 2007 | 12:33 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
No idea what you mean now mike, i totally totally suck with electrics, will i bugger the coil or flamer box thing if i turn it on with the + and - the wrong way round?
Old Oct 1, 2007 | 12:41 PM
CharlieSaff's Avatar
CharlieSaff
If it contains a capacitor which it may well do, then YES.
If you have got a multimeter put it onto the diode testing mode (continuity), and put one multimeter wire on the white and one on the yellow. If the multimeter bleeps or shows a reading very close to zero then they should be as Mike has said
To check multimeter is in the right mode, put the two wires together and if it bleeps/reads near to zero then it is
Old Oct 1, 2007 | 12:44 PM
Mike Rainbird
Caraholic
What he said .
Old Oct 1, 2007 | 12:52 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Oh thats just dandy, as I havent got a multimeter
Old Oct 1, 2007 | 01:03 PM
Mike Rainbird
Caraholic
SOMEONE at Future will have !
Old Oct 2, 2007 | 11:38 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Well as nobody had a multimeter handy I just got a car battery and picked a wire at random, hey, its 50-50 innit
It worked!
But my curiosity got the better of me so I swapped the wires around
It still worked!
BUT the noises the sparkplug makes are different depending on which wire goes to pos, and which to neg
One way its a high pitched "eeeeeeeeeeeeeeee" noise, other way it sounds like bad TV radio interferance/static. Spark looks thinner but more constant and stronger on the "eeeeeeeeeeeee", and the sparks much wider but almost see-thru on the interferance/static noise way.
Which way is right? Im guessing "eeeeeeeeeeeeeeeeeee" as im sure its what it used to do on the Cossie
Old Oct 2, 2007 | 11:52 AM
Fudgey's Avatar
Fudgey
Baby Cheesus
i think its the eee i eeeeee i ooooooo noise
Old Oct 2, 2007 | 11:57 AM
KSA-Cossie's Avatar
KSA-Cossie
pmsl at eeeeeeeeeeeee
Old Oct 2, 2007 | 11:58 AM
Charlie Chalk
Unknown.
Steve, Once you know what goes where.. can you do a CAD drawing on paint for me please
Old Oct 2, 2007 | 12:02 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Radders, ive NO fucking idea about yours
Live to battery.
Earth to ground/battery.
Positive coil connector.
Negative coil connector.
Not sure why theres a 5th one, my guess is its some kind of ign cut switch or summat that can be grounded on a switch if you wanna use it, so prob dont need it.
Its time to randomly guess what colour is what wire I think mate, like I did mine Hey, it was free
Old Oct 2, 2007 | 12:03 PM
Charlie Chalk
Unknown.
Oh well...
Will report back sometime in the near future
Old Oct 2, 2007 | 12:05 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
My advice is use a battery to test it on thats not in your pride and joy, or at least have a fire extinguisher handy
I tested on the mondeos battery, it didnt go near the chaser till i was sure nowt would explode
Old Oct 2, 2007 | 12:13 PM
Charlie Chalk
Unknown.
Yeah I will LOL
Cheers though
Old Oct 2, 2007 | 12:17 PM
Charlie Chalk
Unknown.
Just found this... Whats the 10amp fuse for?
This Kit contains the following:
Full fitting instructions. Ignition coil control box
Ignition coil. Spark plug.
Ignition lead. Arming switch with 4meters of cable.
Fuse holder. Spark plug fixing boss.
Rubber grommet. Fixing screws.
Cable ties. 10amp Fuse + Holder
Old Oct 2, 2007 | 12:28 PM
rsnissan's Avatar
rsnissan
fuse for the live............................
as the shamen always say eeee eeeeeeeeeeeeeeee's are good
Old Oct 2, 2007 | 12:34 PM
Charlie Chalk
Unknown.
So what goes where
Old Oct 2, 2007 | 02:02 PM
dumped's Avatar
dumped
you do know pulsars have fuel over run cut off as standard?
Old Oct 2, 2007 | 02:04 PM
Charlie Chalk
Unknown.
nope... just got the car..
Old Oct 2, 2007 | 02:06 PM
dumped's Avatar
dumped
its ok, just use trailing throttle to get huge boofs from the back.
Old Oct 2, 2007 | 02:14 PM
Magic Numbers's Avatar
Magic Numbers
And what kind of boofs are they?
Rad - I used to get nice flames from mine when I was running a bar of boost and they weren't small ones either! But I'm sure the addition of the kit will improve flames
Old Oct 2, 2007 | 02:16 PM
boXXer's Avatar
boXXer
GASH!
can i have one.
Old Oct 2, 2007 | 02:35 PM
CharlieSaff
Mike,
Do you know how to/have a circuit board layout with a component list of how to make the control boxes?
I'd assume it's just some sort of beefed up 555 timer circuit or something?
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
