Radtec Rs500 i/cooler,hose too small,help please.
Old Jan 20, 2004 | 02:34 PM
Default Radtec Rs500 i/cooler,hose too small,help please.
Iv'e tried to fit my Radtec 500 i/cooler but the hose that goes from the turbo to the i/cooler seems too small (its the original ford hose orange sort of coloured one). Iv'e measured the outlets of the i/cooler & they are about 63-64mm across but the hose is the same diameter. Iv'e also measured my old 4x4 cooler & the outlets are slightly smaller 61-62mm. Are the aftermarket silcone hoses slightly bigger to fit this i/cooler, has anyone else had this problem.
Cheers Simon.
Old Apr 22, 2004 | 06:41 AM
Hello Simon,if you need some help give me a call and i will sort it out for you,dont really understand why it doesn't fit.01543 502525 ask for Keith.
Old Apr 22, 2004 | 05:06 PM
Yeah had exactly the same problem simonc..... Used a bit of grease and a Snap-On hose tool to get it on..... but bit of grease and blunt flat blade screwdriver should do!
Paul T
Old Apr 24, 2004 | 07:55 AM
ML's Avatar
ML
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fudgey
21
Sep 30, 2015 06:19 PM
