need help tuning escort rs t
Old Sep 27, 2007 | 12:24 PM
b3v4n's Avatar
b3v4n
Default need help tuning escort rs t
im tuning up my escort and im needing some help 2get the best power out of it. i have bought a radtec intercoller and a t3/4 turbo and iv got high performance cams k&n mongoose exhaust and need advice on the injection system so any help would be good??
Old Sep 28, 2007 | 11:29 AM
Maki's Avatar
Maki
You've already done mistakes, so you had to ask this before you buy things Now it's up to you to learn from your own mistakes
First of all you had to start from the chip and stronger -31 actuator, then filter, exhaust, cooler, and only then bigger T3 (no way T3/4 as it is too big for 1.6) with this you could run 17 psi max. Then you had to lower CR by machining the pistons down by at least 1.5 mm and boost it up to 21 psi, with good set up of fueling.
Dr. Ickxs
Sep 15, 2015 10:15 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
RSBryden
Sep 6, 2015 08:39 PM
