turbos V superchargers
Old Sep 24, 2007 | 04:47 PM
RichieST's Avatar
RichieST
Default turbos V superchargers
Hi guys and gals
Whats the pros and cons of turbos and superchargers? I'm just wondering why turbo'ing is far more common than supercharging, when supercharging seems to be the more simpler route?
Thanks
Rich
Old Sep 24, 2007 | 04:50 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
simpler? its more complicated.
why is it simpler?
Old Sep 24, 2007 | 04:51 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
turbos are more economical broadly speaking
Old Sep 24, 2007 | 04:59 PM
RichieST's Avatar
RichieST
why is it simpler?
well i was hoping you could tell me that
Old Sep 24, 2007 | 05:06 PM
joshF's Avatar
joshF
superchargers dont lag like a turbo coz there connected directly to the crank.and dont rely on exhuarst gases to spool it up.
Old Sep 24, 2007 | 05:09 PM
mikee_rs's Avatar
mikee_rs
a supercharger saps power to run it. a turbo is using the waste gas so doesnt use up any power
Old Sep 24, 2007 | 06:41 PM
SuperchargedXR4's Avatar
SuperchargedXR4
It depends on which noise you like bestest
Old Sep 24, 2007 | 07:00 PM
Jamz's Avatar
Jamz
Depends what type of supercharger you use.
Generally roots and screw superchargers aren't "laggy" but centrifugal(sp?) blowers are.
Old Sep 24, 2007 | 07:03 PM
big_wig_074's Avatar
big_wig_074
can be more expensive to supercharge,and theres more scope for power with turbos usually
Old Sep 24, 2007 | 07:08 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
What?
Yeah, really laggy
Those types of chargers give different power delivery, but none are laggy in any way, they give a sharper throttle response than most n/a engines would.
Its not even possible for em to be laggy.
And the way centrifugal ones deliver the power can help drivability on some cars massivley, but lag never would.
Old Sep 24, 2007 | 07:12 PM
Jamz's Avatar
Jamz
I KNEW you reply with that, I was trying to put it in terms he might understand hence the quotes around the word laggy
Old Sep 25, 2007 | 06:13 AM
Simply a supercharger is correctly a term used to describe any forced induction ie turbo or as we all refer to a supercharger being mechanically driven.
A supercharger will use more fuel as it is being driven even when not needed, and don't have that much scope for further power hikes compared to your average turbo car which by using a waste by product to create forced induction is more effecient.
Lag is nowhere near as bad now as the early days of turbo cars, but any mechanically driven compressor/supercharger is going to have the edge lower down.
Superchargers are expensive to manufacture and are bulky.
Turbo's are comapct and cheap to make but have a much narrower window of power.
A lot of work was done in the HYPERBAR experiments to further aid the suitability of turbo's.
Old Sep 25, 2007 | 07:30 AM
Chip's Avatar
Chip
Its "boost threshold" not lag you mean of course.
Old Sep 25, 2007 | 07:32 AM
Chip's Avatar
Chip
Not true actually the turbo causes a restriction in the exhaust flow of the engine, this means that cylinder pressures on the exhaust stroke are increased, so the engine is still having to work against it to turn it.
There is a quite shocking amount of misrepresentation in this thread generally TBH!
Old Sep 25, 2007 | 08:15 AM
foreigneRS's Avatar
foreigneRS
Testing the future
agreed.
not necessarily - if a very small turbo is used then it could be responsive from idle but would be restrictive at higher rpm
again, not necessarily. especially in the case of variable vane turbo's
Old Sep 25, 2007 | 11:26 AM
percybigun's Avatar
percybigun
Twistin me melon man
i've got a supercharged (jackson racing) zetec and a turboed (T28) zetec, the turbo is much much much better.
not that the supercharger is bad, i love it to bits but i am now a turbo convert.
yes sure the supercharger has more response but the turbo only has very very slight lag and then its party time compared to the supercharger.
i see you have a focus so i'm assuming its that you are on about forced induction on. well having got both on the same type of engines as yours, my advice would be turbo it
Old Sep 25, 2007 | 11:51 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
IMHO crappy bolt on turbo or supercharger kits cant and dont give a true representation of what they are like, makes superchargers seem nowt special, and makes turbos seem lag free lovlies.
This might be the case on low boost/power setups, but not in general.
And no matter how responsive and small a turbo is, it never gives the same feeling, theres always "lag", without ALS throttle position and acceleration is never directly proportional.
Saying all that though, id go turbo 99% of times as its much easier and more adaptable when you want to change stuff.
markk
Sep 9, 2015 08:11 AM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
