any body got a pic of a rear axle bush on a 2wd cossie
Old Oct 3, 2004 | 05:16 PM
yogi's Avatar
yogi
Default any body got a pic of a rear axle bush on a 2wd cossie
mine as gone because the rear axle is moving back and forward like a dont no wat but ford want 60 quid each fooking rip off but i dont no wat they look like do you need an iner bush and outer bush for the axle its the passenger side theres a place in the back of fastford deflex that does them for 4 quid each but im not sure they are the write 1 also are they a bugger to get out
Old Oct 3, 2004 | 05:42 PM
Guinnless's Avatar
Guinnless
ou need to check what is actually moving - the beam or the trailing arms. Replace the beam bushes with poly but for the trailing arm the original spherical bearing (not bushes) are the best.
Old Oct 3, 2004 | 05:48 PM
yogi's Avatar
yogi
the part thats moving is the bit wat goes bit like a u shapedunno if that makes any sense
Old Oct 3, 2004 | 05:51 PM
righthooker's Avatar
righthooker
had similar problem ,for me it was the round doughnut looking bush ,18 quid each from ford.sorry not to much help now i read it back
Old Oct 3, 2004 | 06:36 PM
righthooker
dose this help these were my problem
Old Oct 3, 2004 | 06:37 PM
The Youth.'s Avatar
The Youth.
that is the rear bushes inner and outer, it does sound like you need the big outer rear beam bushes instead of these.
steve
Old Oct 3, 2004 | 07:43 PM
yogi's Avatar
yogi
i have got a picture of wat i need but i carnt upload dont no how to any help i can email it to some 1 if that helps folks
Old Oct 3, 2004 | 07:48 PM
yogi's Avatar
yogi
but youth does look like there the ones i need 60 quid each from ford are these the same this is a rear arm bush
Old Oct 3, 2004 | 09:44 PM
The Youth.'s Avatar
The Youth.
It is a lot of money but you really should put gen ford bushes in as they are sphericle and unlike normal non cosworth bushes( hence the increased cost) by design they allow no sideways movement unlike poly bushes.
steve
ps nice to see more locals on here!!
155lee
Aug 14, 2015 11:21 AM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
Old ford
Jul 31, 2015 06:50 AM
