P100 modifications???????
Old Sep 22, 2007 | 06:30 PM
BEN FRST's Avatar
BEN FRST
Default P100 modifications???????
Right i've brought a new work tub a Jplate P100 with a TD engine and i am going to cossie it. Now the question is has any body done this now i've seen them done so i know its possible but not really paid much attention to them.
Can you use the rear beam off a cossie or do you mod the original, i know that all of the front is the same as any sierra so thats not a problem.
Does any body have any pictures of them complete?
Old Sep 22, 2007 | 06:38 PM
jacko's Avatar
jacko
the front suspension is spaced with shims to make it higher so that needs to be lowered and you can use a capri rear set up ant all the hubs and brakes need changing
Old Sep 22, 2007 | 08:24 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you need to weld in the sierra beam mounts at the rear
Old Sep 23, 2007 | 08:17 PM
BEN FRST's Avatar
BEN FRST
come on guys you must have more info than that
Old Sep 23, 2007 | 09:12 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
ask for rob
http://www.normandyautosalvage.co.uk
as far as i know he was the 1st to do a cossie p100
hes done 10 to date so should be able to help you out
Ian1964
12
Jan 26, 2021 11:57 AM
Chopshop85
Oct 22, 2015 09:26 PM
richierich1986
Sep 18, 2015 03:29 PM
