what oil should i use for road and trackdays?
as above, what oil should i use in my cossie? its got a 4,000 mile engine in it (so not too much wear and tear)...... the oil i'm using makes the engine sound like a tractor after a 20 mins of flat out driving....leave it running to cool down etc and it goes quiet again.. any suggestions? cheers tony
Hi Tone, I use Silkolene Pro S 10W-50. Should be okay for the odd trackday too, but if in doubt the Oilman ( http://www.opieoils.co.uk/ ) can advise...
What have you got in it at the minute?
Hope you're well
Hope you're well
hi bill i'm cool ta... long time no hear.. i hope things are ok your end? i got magnatec in it at the moment... ok for normal road use but not up to track tempratures... cheers mate
Castrol is famous for losing it's viscosity like this.
Use Silkolene pro s, and fitr a stat oil cooler if doing track days again, as oil is obviously roasting, remember the oil is always around 30/40C hotter than the water and does as much cooling.
nico12
Dec 31, 2015 04:42 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
truffleshuffle
Sep 10, 2015 09:35 PM
