Will a 16" MO go over 330mm AP 4 Pots?
Old Oct 3, 2004 | 11:17 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Default Will a 16" MO go over 330mm AP 4 Pots?
As above please
Old Oct 3, 2004 | 11:26 AM
DazC's Avatar
DazC
Replied on RSOC.
Old Oct 3, 2004 | 11:31 AM
Tony Turbo's Avatar
Tony Turbo
Me too, lol. Just want a few more opinions
Old Oct 3, 2004 | 11:33 AM
Newts's Avatar
Newts
My MO 17's went over AP355 six pots so I guess yes as its about 25mm to an inch.
Newts
Old Oct 3, 2004 | 03:13 PM
Porkie's Avatar
Porkie
Depends on the wheels offset and size of the caliper and how its mounted I reckon Tony. Tricky one...
Old Oct 3, 2004 | 03:33 PM
CozzyBrom's Avatar
CozzyBrom
yes they will mate
disc offset will need to be deeper to clear the mos as the not very caliper freindly as the older mos or raclines due to the gay turned in spoke hitting the caliper
i recenty fitted 315s to a rst using mondy road rims and they cleared easlery
hope this helps
Old Oct 3, 2004 | 04:09 PM
tracktoy's Avatar
tracktoy
Originally Posted by cozzybrom
yes they will mate
hope this helps
the older ones look soo much better
Old Oct 3, 2004 | 04:22 PM
Tony Turbo's Avatar
Tony Turbo
Thanks guys.
Lee - Martin is going to make me some brackets and bells for your old wheels, ET40. I want a set of 16's for track with some slicks on. If I stick to the same offset for the 16's would they go?
I don't really want a higher offset, the 17's stick in enough as it is.
CheeRS
Old Oct 3, 2004 | 05:05 PM
Ginge !'s Avatar
Ginge !
just finding my feet
brom wonder whos those wheels where for
trust me brom knows a shite load about brakes, it when he tries to explain i get confused
Old Oct 4, 2004 | 07:17 AM
Tony Turbo's Avatar
Tony Turbo
Old Oct 4, 2004 | 07:58 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You mean lower offset!! LOL. The higher the number, the further under the car they will sit.
Are your Mo's 7x17? My 7x17 Pro Race wheels were ET35, so would have sat slightly further out than your Mo's, if they are the same size. I reckon you will struggle with ET40, especially if they are not particularly good in terms of caliper clearance. My current wheels are also ET35 and are 7x16 and I had to use a 5mm Spacer (actually only needed 3mm). The AP Calipers are a VERY similar shape to the Brembo's.
Also, if you go for a 16", it will need to be a 7x16 to be comparable in terms of offset.
As others have said, it really depends on the offset of the Bells and Caliper Brackets. You can put a deeper offset on the bell, make the caliper to suit and gain yourself a little that way. You don't have ultimate flexibility, but may gain a few mm's.
Old Oct 4, 2004 | 08:13 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Tony,
Providing you order the wheels with the correct size and offset, you won't have a problem.
I would say that 7½ x 16 ET 37 would be okay, but I would have to check first.
Old Oct 4, 2004 | 09:02 AM
Christian and Beccy
#1 in Spelling Club
But IMO 7 1/2 on an RST is pants. This would mean running 215 tyres. They are bad enough on 205's.
Old Oct 4, 2004 | 09:06 AM
Mike Rainbird
Caraholic
Then you would need to get 7s with an offset that would put the outside of the wheel in the same place as the ET37 7½s...
Old Oct 4, 2004 | 09:08 AM
Christian and Beccy
#1 in Spelling Club
Mike, what are Mo's like generally in terms of caliper clearance?? Are they better or worse than a 'normal' Alloy wheel??
Old Oct 4, 2004 | 09:11 AM
Mike Rainbird
Caraholic
Better than "most", due to their Motorsport designed nature.
Old Oct 4, 2004 | 09:21 AM
Christian and Beccy
#1 in Spelling Club
OK, I figured that because they are designed to be strong more than light, that they might be 'chunkier' on the spokes.
My 7x17" Pro Race 1's were ET35, but they had a good design for Caliper clearance. They cleared my Brembo's/330's by a mile.
My 7x16" Pro Race 2's were also ET35, they have a design that isn't much different to a 'normal' Alloy Wheel and I had to use a small spacer to clear the brakes. I also have to have the wheels balanced often as the calipers knock the balance weights off!!
Another idea, will Compomotive provide cross sectional working drawings of their wheels??
Old Oct 4, 2004 | 10:29 AM
Tony Turbo's Avatar
Tony Turbo
I found most of that quite confussing lol. I see what you are both saying.
But would it be easier if I sold my 17's to get some ET35 wheels, then the bell and bracket would be made for that offset (for the road) then when I put the 16's on, I stick with the same offset, or lower to bring them out more???
I was actually thinking of 16 x 8 wheels with a nice wide slick Either a MO, or a set of Monte wheels. Damo is pretty sure that he could get 330's behind his wheel, but the weights would have to be moved.
Mr C - I know what I mean lol
Old Oct 4, 2004 | 10:30 AM
Tony Turbo's Avatar
Tony Turbo
I mean lets face it... I will probably only use these wheels a few times a year anyway.
Old Oct 4, 2004 | 09:11 PM
Tony Turbo's Avatar
Tony Turbo
UP
Old Oct 4, 2004 | 09:57 PM
Andy-R's Avatar
Andy-R
Pic of 8" ET40 problamatic with the S2 bodykit!
HTH
Old Oct 4, 2004 | 10:02 PM
Christian and Beccy
#1 in Spelling Club
Andy,
8" wide on an RST, how does that drive??
Old Oct 4, 2004 | 10:10 PM
Andy-R's Avatar
Andy-R
It drives well Christian, took a lot to get the geometry spot on a little over 5 hours , will be right at home on track which is where am goint to be using it!
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
OrionRST200bhp
Sep 29, 2015 08:30 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Minirotty
11
Sep 15, 2015 10:16 PM
