koni adjustable help
Old Sep 19, 2007 | 03:23 PM
rs_cabby's Avatar
rs_cabby
Default koni adjustable help
hi all, one of the adjusters wont turn either way on one of my shocks,
does this mean its knackered or is there any way i can free it off?
i dont want to put too much pressure on it and snap it off.
Old Sep 19, 2007 | 05:29 PM
Turbo-Beal's Avatar
Turbo-Beal
Are you adjusting them under load? When i fitted mine it said you must jack up the car and then adjust them. Probably not the issue but thought i would mention
Old Sep 19, 2007 | 09:45 PM
BlueFiesta85's Avatar
BlueFiesta85
try putting some wd40 on it and use a plier to free it mate, this helped on a mates car with no probs
Old Sep 21, 2007 | 06:59 AM
Aaroncast's Avatar
Aaroncast
!! JACKING UP CAR HAS NOTHING TO DO WITH IT!!-HA-HA/LOL
IF WE HAD TO DO THAT EVERY TIME IT CAME INTO SERVICE WE WOULD LOOSE LOADS OF TIME----------------
IF ITS TIGHT DONT USE THE KONI AJUSTER AS IT WILL RUIN IT/USE SOME WD ON IT AND MOLE GRIPS ETC-SOUNDS LIKE ITS OVERTIGHTENED FROM LAST ADJUSTMENT
--ON ITS WHEELS OR NOT IT DONT MATTER!!!!!!!
Old Sep 22, 2007 | 09:40 AM
Turbo-Beal's Avatar
Turbo-Beal
You make it sound like its somthing you do every day but it obviously isnt! Didnt know that adjusting koni's was part of every service lol. Like i said earlyier koni advise you to adust them off load and i personally woulnt do it any other way. Like i said didnt think it would be the issue but thought i would just mention it! No need to take the piss when pll are just trying to help
Old Sep 22, 2007 | 10:10 AM
JesseT's Avatar
JesseT
It's only the older Koni shocks (non top-adjustable) that need to be adjusted at full length.
Old Sep 22, 2007 | 02:23 PM
MarkXr's Avatar
MarkXr
The older, non top adjustables have to be removed from the car to adjust. This is because you have to push them fully inwards and then rotate the rod to adjust.
The top adjustables can be set with the car on its wheels. Never had a problem with doing so.
yatta
May 21, 2016 10:31 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
truffleshuffle
Sep 10, 2015 09:35 PM
