Escort RS Turbo standard cam
Old Sep 19, 2007 | 02:13 PM
Fiesta SuperSport's Avatar
Fiesta SuperSport
Default Escort RS Turbo standard cam
Hey peeps!
Can anyone offer any advice on where to get a decent standard RS turbo cam from? Do ford still sell them?
I have tried a couple of second hand ones and they have all been as bad as the original one! I dont really want to go for an aftermarket cam, as I would be happy with the car making 160-180 bhp.
Car just feels flat and unresponsive once on boost
Basic spec. is standard engine / head / turbo / Intercooler. Magnex exhaust, K & N Filter, -31, chipped ECU, spikes at 18 psi holds 16 psi.
Car was rolling roaded and only made 136 bhp, the dyno operator stated that the cam wear was to blame for the low power output.
Any advice would be great
Old Sep 19, 2007 | 02:26 PM
haz87's Avatar
haz87
Any motorfactors
Old Sep 19, 2007 | 02:39 PM
JesseT's Avatar
JesseT
Have you checked the obvious like ignition timing, cam timing and fuelling?
Old Sep 19, 2007 | 08:56 PM
Rick's Avatar
Rick
motorfactors do them
does it look worn?
Old Sep 20, 2007 | 03:59 PM
Fiesta SuperSport
Cheers for the replies
I know most motor factors would either stock or be able to get a cam kit, I really wanted to know if there was any manufacturer that was better than the others
The fueling / cam timing and ignition timing was checked at the rolling road and found to be good!
Out of the three cams I have tried, they all look really worn, particulaly at the distributer end!
Thanks again
Old Sep 20, 2007 | 04:23 PM
Rick's Avatar
Rick
then this is your problem. The motorfactor cams are all made in the same factory, they are good quality. Expect to pay Ł90 max for cam and followers.
Old Feb 24, 2013 | 11:18 PM
davecrook1's Avatar
davecrook1
What motor factors are we talking about.. I cant find a standard cam and followers any where.. Mine is nosey and rattley when revved
Old Feb 24, 2013 | 11:20 PM
simonmcf's Avatar
simonmcf
Maybe get onto carparts express . I know you can get up rated cams from matt Lewis and burtons
Old Feb 25, 2013 | 11:16 AM
Karlos G's Avatar
Karlos G
Balls Deep!
http://www.ebay.co.uk/itm/Camshaft-C...item257a943e3f
http://www.ebay.co.uk/itm/FORD-rs-tu...item2564c43d7e
http://www.ebay.co.uk/itm/FORD-ESCOR...item45fe61d335
Old Mar 4, 2013 | 07:16 PM
Mixja's Avatar
Mixja
420
Still available from ford I believe...
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
Vincereese
Aug 16, 2015 06:38 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
