MK4 Cabriolet 1.9 CVH Turbo Build 03/01/08 trims in!!!!!
well after buying Martrs old purple rs turbo a few months back,
I had a bit of a misshap with the car an injector seal split and leaked fuel over the exhaust causing the front end of the car to be badly damaged
so i set out to find a donor car for its runnig gear
I picked this 1988 black cabriolet up for £600 ang have stared buying bits to build it up into a turbo cab heres a few pics of the engine so far,
Since the engine was out of the purple rs ive repalce every gasket and change the cam for a newman cam wtih solid lifters
ENGINE SPEC
1.9 cvh 1800cc crank low comp pistons
stage 3 jamsort heat with huge ports
Newman cam
efi polished inlet dark greens
l6 cosworth ecu ect,
il get some more pics of stuff up a soon as th cameras charged thanks for looking!!!
ENGINE SPEC
Newman cam
Originally Posted by NATH-RSZT
Car looks nice but thats a 1.6 cvh engine
Looking good Dean!! Never realised you wanted to feel the wind in you ever thinning hair!!
Even I've got more hair on my head than you!! Be carefull or the rest might blow off!!
thin hair is better than no hair baldy!!!!
Bit of an update,
Afew pics of the brakes im going to be running which are AP 4 pots
with 335mm discs i will be running a rear cosworth brake setup aswell
Also pics of my burnt rocker cover of the puple rs lol
As for the engine managment its going to be running l6 cosworth on green injectors 3 bar ect
hopfully going to get the cabriolet off to the bodyshop as soon as can't decide on a colour tho yet
Going to be runnig a 4x4 cosworth turbo and exhaust housing hopefull at about 20 psi depending on the fueling!!!
Pics!!!
Pics!!!
finally got the engine out of the cab this week
Ordered a group a coil an some manifold studs and spent
Most of the week making things for the car
I painted up the AP calipers in shiny gloss black!
as they were looking a bit worse for where lol
Ive made a pod for my water temp gauge and ACT gauge all
The cab is totally stripped down and ready for paint
just waiting on abonnet and spoiler for it
Thinking of smoothing the bumpers any commetns welcome!!!
Cheers for looking!!
PICS!!!!!!!
PICS!!!!!!!
:gayflag:
after all you are Baby Lotion Daz C arent you?
And as For You AJC
that 16i aint going no where!!!!!
Bit of a small update on the cab,
Polished the inlet up with a dremell today looks
Also repaired my l6 cosworth loom after the fire damage! took
me 2 hours!!!!
Then spent the rest of the day choping out the old alarm
and engine loom out of the cab what a mess
and gave my master cylinder a quick paint!!
Been on eBay aswell spending money i havn't got lol got some black vac hose ond black breather hoses
piccys
me 2 hours!!!!
piccys
:gayflag:
And as For You AJC
And no, smooth bumpers are rather homo!!!
Well after a few months of no progress with the cab
Its finally at the body shop
The shell is beeing fully stripped down a restored
Im having it fully delocked turbo bonnet and arches fiited
2 new front wings fitted and replaced both doors with some solid ones lol
after weeks of searching i managed to get hold of a genuine rs spolier
for just £20
As for the colour its beeing painted in ford panther black
got some pics of it will get more as soon as its poss lol
piccys!!!!
the engine so far!!!
for just £20
piccys!!!!
