temp guage going really low??!!
Old Sep 12, 2007 | 11:01 PM
Chris69's Avatar
Chris69
Default temp guage going really low??!!
for some reason when sitting on a dual carriageway a little above that legal number but not foot to floor- kinda just holding +boost pressure and maintaining speed my water temp guage goes really low
it goes from normal range to below the actual bottom bit as if its suddenly gone mega cold
any ideas- goes back into normal range when i slow down or stop quite quickly aswell
never use to do it, any ideas wots causing it??
Old Sep 12, 2007 | 11:07 PM
gaz s1's Avatar
gaz s1
Thermostat stuck open?
Old Sep 12, 2007 | 11:22 PM
Chris69's Avatar
Chris69
could be, only recently put a new spring and clip etc in it when i rebuilt her 500miles ago so thats quite annoying- one thing to check- any more suggestions
Old Sep 12, 2007 | 11:31 PM
antony215's Avatar
antony215
Escort Rs Turbo
Sure it's not just a dodgy/loose wire on the sensor
Old Sep 13, 2007 | 04:33 AM
JesseT's Avatar
JesseT
Probably a 78/82 deg thermostat + autumn coming.
Old Sep 13, 2007 | 08:00 PM
Chris69's Avatar
Chris69
so others peeps r sturbos do this- just never seen it before, if its nothing to worry bout i'll leave it
Old Sep 13, 2007 | 09:09 PM
Mixja's Avatar
Mixja
420
used to do it on my old s2 running a chargecooler, needle sat right near the bottom normally, dropped a bit when i gave it some beans... thought it was strange!! seemed fine tho...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
Tank Mike
Sep 26, 2015 08:07 AM
