2.0 16v Si-Help needed
Old Sep 12, 2007 | 06:18 PM
onslack's Avatar
onslack
Default 2.0 16v Si-Help needed
right this is doing my head in now
since day one of my 2.0 conversion my car's rev's hunt. i was told to replace the plugs and leads.
i replaced the plugs and leads for standard ford ones, i think replaced my iscv with a fairly clean second hand one, i also replaced the tps while i as there
the other day my car would run,but as soon as the rev's dropped it would cut out,i replaced the lambda sensor and the car started idling oki replaced the maf while i was at it
i then disconnected the water temp sensor that sends signals to the ecu and the car idles ok and the rev's stopped hunting
i replaced the water temp sensor(new one) today and the car still does it Confused , when i disconnect it ,it seems to idle ok but smells very rich
the battery has been off since 10.30am this morning and was reconnected at 5.30pm, so the ecu was reset
i dont know what else to try or to check
i couldn't feel any vacum leaks, a few weeks ago the breather hose under the coil pack was replaced
but it does sound like a "tuff tuff" noise coming from the engine when i switch it off, but not a clue where its coming from as it only me, and i can hear it when i am by the drivers seat
Old Sep 12, 2007 | 06:48 PM
Wardy257's Avatar
Wardy257
Do you have the correct ECU for the engine? Are all the sensors the correct sensors for the ECU?
Old Sep 12, 2007 | 07:23 PM
onslack's Avatar
onslack
yeah i am using a desk ecu as only 3 ecu's work, all my sensors are correct
Old Sep 12, 2007 | 08:11 PM
boost mad's Avatar
boost mad
thinking about it.... could it be a badly adjusted TPS ?
Old Sep 13, 2007 | 08:36 AM
onslack's Avatar
onslack
hi alex
it could be, as i was talking to someone and they said that they didn't think the 1.6 TPS of the SI would work with a 2.0 throttle body
when my conversion was done a friend( or so called friend) did the inlet side while i was reconnecting read hoses etc. and i think he used the 1.6 TPS
i have a 2.0 TPS at home i will try that
Old Sep 13, 2007 | 04:10 PM
Wardy257's Avatar
Wardy257
Unplug the MAF and see if it gets better.
Old Sep 13, 2007 | 07:02 PM
onslack's Avatar
onslack
i have tried unplugging the maf, it does nothing still does the same thing
Old Sep 13, 2007 | 07:21 PM
Wardy257's Avatar
Wardy257
Very strange. I think you need to check your look over very carefully checking for chaffed wires, dirty conections etc. Continuity check all the sensor wire and volt drop each sensor and so on.
Old Sep 14, 2007 | 11:16 AM
onslack's Avatar
onslack
thank you again for your help, i will get some help with this as i dont have a clue
Old Sep 18, 2007 | 11:34 AM
onslack's Avatar
onslack
took it to a friend yesterday, hooked it up to thier diagnostic machine and it picked up my EGR which it would as i removed it
and it picked up that i am running lean at my lambda, so i am having my timing checked this week and going to hook it back up and see what it says
it seems to have stoppped hunting now and idles a little bit better
i think thr guy who did my inlet used the wrong gaskets, think he used the 2.0 inlet gasket with my rs1800 inlet so those will be getting replaced asap
so in short i am getting there slowly
just did my GF's 2.0 conversiob this weekend
http://www.fiesta-si.com/forum/viewtopic.php?t=8668
its runs sweet as a nut , so i'd best pull my finger out and get mine sorted
JoeyBoyden
20
Aug 22, 2015 03:23 PM
col93saphcos
Aug 7, 2015 03:21 PM
