Q about actuator
Hello guys and girls.
I have bought my first RST -87 and has some questions.
I changed the ECU and actuator on the car today.
But the old actuator looked like this:
And the new like this:
As you can see they dont have the same rod to the wastegate.
Is there someone that has changed the actuator on their car and has a good way to attach this to the turbo?
This is quite normal,
If you undo the locknut (11mm I think) then the end with the loop on should screw off and then these should go on your new actuator.
Make sure you get your fueling and boost pressure checked properly!
JK12
33
Apr 26, 2021 12:09 PM
