Stage 3 Turbo
Old Sep 10, 2007 | 10:26 PM
BlueFiesta85's Avatar
BlueFiesta85
Default Stage 3 Turbo
i have large grs i/c which i will be fitting soon, im also running a standard turbo at the moment with a stage 3 head,cvh34 cam, standard bottom end with arp bolts, i want to have the safest power band out of the current engine, is it worth having a stage 3 turbo also fitted with the the grs?
Old Sep 11, 2007 | 12:32 AM
Fiecos Dan's Avatar
Fiecos Dan
what power do you want, and what rpm do you want to be using?
Old Sep 11, 2007 | 10:12 AM
BlueFiesta85
will be keeping the setup above but with standard rods, so im only looking to get 230 max if possible, not to sure what rpm the stage 3 starts to kick in so some advice would be helpful.
Old Sep 11, 2007 | 07:14 PM
Fiecos Dan's Avatar
Fiecos Dan
never driven a Stg3 RST, but i run a cossie T3 on my Xr2tt, and it will be the same on spool.
looking @ 3500 rpm for full boost, 250bhp ish max.
Old Sep 12, 2007 | 01:18 PM
JamboRS's Avatar
JamboRS
focus rs 1672
my stg 3 t3 was on full boost by 2800rpm
Old Sep 15, 2007 | 10:49 AM
Fiecos Dan's Avatar
Fiecos Dan
Matters what you call full boost?
my 4wd cos T3 hits 20psi by 3000, and 28psi by 3400 ish rpm.
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
