best to use on white
when i first got my car the paint work was like glass i have washed and polished it evey weekend but it dont shine like it use to iv heard about clay or some thing like that wot is it and wher can i get it from or wot else can i use
Run your hand over the polished panels. Do they feel smooth or rough? If they are rough then you need to clay it. Clay removes ingrained dirt and leaves a nice smooth surface. Try www.detailedobsession.co.uk or www.detailingworld.co.uk for help and advice.
If you cant feel any ingrained particles with your hand try putting your fingers inside a plastice bag (sandwich bag, cigarette wrapper) and use your fingertips to "feel" the paint work if you can feel bumps then claying is probably required if you want paint that is smooth as glass.
The clay will remove any protection on the paint so you will need to polish and wax/seal the paint for the best finish.
HTH
Scotsbil
HTH
Scotsbil
SMILER258
Sep 28, 2015 09:04 AM
